FireryDawn 3 Report post Posted August 16, 2014 does anyone know if a getrag 260 off an M20 will just bolt straight onto a M40? and if so, are the splines on the clutch plate the same? Quote Share this post Link to post Share on other sites
BM WORLD 1295 Report post Posted August 16, 2014 will bolt up , will sit on a different angle though , bottom small 3 bolts holes don't line up. clutches , flywheels , etc will interchange , just make sure your starter matches the flywheel , and the clutch is stong enough for the engine etc 260 is longer than a 240 etc , so driveshaft will need to be different to suit etc Quote Share this post Link to post Share on other sites
FireryDawn 3 Report post Posted August 16, 2014 will bolt up , will sit on a different angle though , bottom small 3 bolts holes don't line up. clutches , flywheels , etc will interchange , just make sure your starter matches the flywheel , and the clutch is stong enough for the engine etc 260 is longer than a 240 etc , so driveshaft will need to be different to suit etc sweet cheers! iv got driveshafts and everything, this was all outa my parts car Quote Share this post Link to post Share on other sites
