Rohil 30 Report post Posted August 30, 2014 Hi guys, So i'v been searching all over and found that in order to stroke the M20B23 engine, i will need to change the fuel system from the earlier L-Jetronic to the later Motronic system. Is this correct? And if so, has anyone done this and can provide pointers on how to go about this? Any information would be appreciated Cheers in advance! Quote Share this post Link to post Share on other sites
Driftit 2187 Report post Posted August 31, 2014 I was going to stroke one of my m20s a while back. And was told this had to be done. I actually have a complete loom and ecu to do this if you need it. Quote Share this post Link to post Share on other sites
Rohil 30 Report post Posted August 31, 2014 I need all the information i can get before i do undertake this job, and parts list etc which im compiling through other forums atm. Did you end up getting any info on changing the fuel system? Quote Share this post Link to post Share on other sites
HELLBM 1661 Report post Posted August 31, 2014 We have all the parts you need. Make a list. Quote Share this post Link to post Share on other sites
Rohil 30 Report post Posted October 4, 2014 Iv contacted you guys, regarding the L-Jet and a manual conversion. Probably need to save a bit but this is the route im going to take hopefully as soon as i can. Thanks again Ray! Quote Share this post Link to post Share on other sites
