JoKer
WTB : E34 540i slushie
price check on transmission, mine is loosing/lost R
265k on clock
failing that Lincon auto's in PN might get a visit OR sell the frigging car fresh WOF & service
5hp 30? Have a good one here. Needs a couple of external seals but otherwise good. Should be cheap at $400.
What model box? I have a good 5hp24 minus bellhousing off a V8.
na a bit different in the electrics etc
hope to see it on the hoist tomorrow, sorry no idea on what I actually could use/# etc
still sulking, dragged my GTB out of the weeds this morning
Edited by JoKer
5hp30 and have stumbled upon the check-ball conspiracy
http://www.noreverse.org/
so fingers crossed may save me some time/effort
Pretty pics of the gearbag solenoids in 1st link below
http://www.bimmerwerkz.com/forum/5-series-e12-e28-e34-e39/e34-540i-5hp30-tranny-question-black-67858.html
http://www.bavarian-board.co.uk/forum_posts.asp?TID=39297
http://forums.bimmerforums.com/forum/showthread.php?1506988-BMW-ZF-5HP30-no-reverse
thanks so far guys, I can hack walking to work for a few more days before I can nail it down/start saving for a freshen up
Edited by JoKer
I have a few 5HP30 repair manuals and bits and pieces in PDF form I can email if you like.
I'd collected them from vague sources around the place.
ok so diff is sweatting horsepower (oil) so going with the Diff being the main issue, any one with some spares/advice?
will 6 cylinder fit? do I need an LSD of will any unit fit etc
Where is it leaking? Sideshafts or input?
How many bolts are there around the sideshaft flange, 6 or 8?
have a 540i diff if needed , but that wont fix your trans issue
Is the diff locking up and not rotating backward or something??
lets just say a BIG BaNG going round a right hand corner low speeds, then clunk clunk clunk clunk with wheel rotation tell be the oil leek isn't only a seal
if it is both things then car is scrap to me
spent 800 on wof / brakes in aug, then its shagged this month, could say that's slightly depressing
will count bolts shortly, being stranded without budget to either fix it or buy another runabout is really choice
std 540i is a large case 8 bolt diff , have one $200 and no a 6cyl diff wont bolt straight in .
some 535i etc use a 8 bolt diff , but have a different front flange
you will have to spend $$$ to get anything "new" and at least you know what you have got....cheer up mate
or
Looking at this listing
would get me mobile again BUT its pickup only, anyone capable of collecting/wrapping and popping it on a pallet?
its heavy and a 2-man lift etc
