Jpclarke89 20 Report post Posted September 11, 2014 Excuse the noobness and repeating something that has probably been asked a thousand times, but what manual g/boxes can be used for an e36 328i manual conversion? I was looking on realOEM and unless I read it incorrectly it seemed all manual transmissions for the e36 are the same, but 325, 328, and m3 have a bigger gearbox output? Some clarification on what will, and won't work would be great Quote Share this post Link to post Share on other sites
KwS 2447 Report post Posted September 11, 2014 Not changing the diff when converting to manual gives some wicked acceleration, but high revs at 100kph. Still usable though. Quote Share this post Link to post Share on other sites
Jpclarke89 20 Report post Posted September 11, 2014 Thanks for clearing that up Ron, I read the output thing through some other forum when I was trying to google answers to no avail. Obviously my knowledge in this area isn't great. Hypothetically speaking (as I wouldn't consider doing this), could you run a getrag 200 or 250G with the m54b28, or would it break easily? And more realistically speaking will the Getrag S5D250G run with the b28 with no issues, as I can imagine the ZF manuals are hard to find/costly? And yes had already planned on changing the diff at the same time, thanks. Quote Share this post Link to post Share on other sites
KwS 2447 Report post Posted September 11, 2014 it'd be fine, the B28 is hardly a powerhouse in the first place. Have some mechanical sympathy and itll keep going. 2 Quote Share this post Link to post Share on other sites
westy 614 Report post Posted September 11, 2014 NZ new 328s with the ZF auto run a 3.07/1 diff. Quote Share this post Link to post Share on other sites
m325i 732 Report post Posted September 11, 2014 Pretty sure my JDM 328i Auto didn't have 4.45 diff. Converted to manual using a '325i' box - real world was like 'Japanese car' ratios. 2nd would top out around 80km. 100km in 5th was just over 3k rpm. Initially I was worried it was too short, but after a while I prefer it. If you did A LOT of open road driving / 100km m.way, I would think twice. Quote Share this post Link to post Share on other sites
KwS 2447 Report post Posted September 11, 2014 yeah, i dont know the ratio of my old 323i diff, but when i converted it to manual using 318i stuff it was great around town but on the open road it was a pain pulling over 3000rpm at 100kph. Was always left wanting a 6th gear. In saying that my M3 pulls about 3000rpm (just below i think) at 100kph and its all good. I wouldnt worry too much about which box you use, just make sure the rest of the hardware (drive shaft, shifter etc) are all suitable for both your engine (4 and 6 cylinder use different hardware) and the gearbox you use. 1 Quote Share this post Link to post Share on other sites
Ahmedsinc 414 Report post Posted September 12, 2014 Pretty sure the jap import 328i autos got a 3.46 final drive, 323i got the 3.64. 3.46 is the ideal ratio IMO, highway rpm are still good but you get far better acceleration than a 3.07 or 3.15. 3.23 would be nice but bloody hard to find locally in medium case size. Is on my priority list of to-dos for my 325i. Quote Share this post Link to post Share on other sites
