pw95 0 Report post Posted September 22, 2014 I want to put a LSD on my e30 Ive got my eye on one its a 3.15LSD from a e32 750iL, will it fit?? and if it does will it work?? Thanks in advance guys and gals Quote Share this post Link to post Share on other sites
e30ftw 432 Report post Posted September 22, 2014 No it won't fit. 750iL will have a large case. You need a small case or medium case, any from e28 / e30 should fit. e28 will need output flanges and rear cover swapped which is easy to do. Depending what you have you want to aim for a 3.64 or higher. 3.15 will be too low for an e30 IMO. In my experience 3.73 or 3.91 is the sweet spot. Quote Share this post Link to post Share on other sites
pw95 0 Report post Posted September 23, 2014 ok cheers bro ill keep looking around Quote Share this post Link to post Share on other sites
_ethrty-Andy_ 2144 Report post Posted September 23, 2014 Thats what i told you when i texted you! 1 Quote Share this post Link to post Share on other sites
pw95 0 Report post Posted September 23, 2014 haha na I read on google that if their both medium case you could probably swap them Quote Share this post Link to post Share on other sites
pw95 0 Report post Posted September 23, 2014 well the insides Quote Share this post Link to post Share on other sites
polley 916 Report post Posted September 23, 2014 Yes you can swap between medium cases but as said before the 750 will be large case Quote Share this post Link to post Share on other sites
Ahmedsinc 414 Report post Posted September 24, 2014 Mate if you can figure out a way to get 210mm internals to work in a 188mm case I'll be all ears!! Quote Share this post Link to post Share on other sites
