bradi65 4 Report post Posted September 27, 2014 Hey guys hope I've posted this in the right place. Just brought a new e30 325i, the clutch seems to be in active the guy I brought it off said that it was just stuck and needs to be freed up, Any ideas on how to get it unstuck ? Could this be the slave cylinder ? Any help would be very appreciated ! Cheers !! Quote Share this post Link to post Share on other sites
Palazzo 533 Report post Posted September 27, 2014 Glenn's advice to me with a similar problem was to put it in gear and turn it over briefly on the starter motor. Obviously make sure the path in front is clear. Assuming the clutch is stuck and not another problem. Quote Share this post Link to post Share on other sites
bradi65 4 Report post Posted September 27, 2014 Glenn's advice to me with a similar problem was to put it in gear and turn it over briefly on the starter motor. Obviously make sure the path in front is clear. Assuming the clutch is stuck and not another problem. I got it started in 1st gear and can drive it around but theres no clutch and no spring to the pedal, could it be the clutch cable ? Quote Share this post Link to post Share on other sites
e30ftw 433 Report post Posted September 27, 2014 It's a hydraulic clutch. If you don't have resistance on the clutch pedal then either the master or slave cylinder is to blame. Master cylinder you will see behind the clutch pedal. Slave is on the passenger side of the gearbox. Quote Share this post Link to post Share on other sites
bradi65 4 Report post Posted September 27, 2014 It's a hydraulic clutch. If you don't have resistance on the clutch pedal then either the master or slave cylinder is to blame. Master cylinder you will see behind the clutch pedal. Slave is on the passenger side of the gearbox. any ideas where to get one online ? I had a look on trademe but cant seem to find much. Quote Share this post Link to post Share on other sites
Cab 148 Report post Posted September 28, 2014 Sterling Brake & Clutch will sell both Quote Share this post Link to post Share on other sites
bradi65 4 Report post Posted September 29, 2014 Sterling Brake & Clutch will sell both Cheers man i got one from BNT today didnt come with the push rod but should be able to use the old one ! hard part will be trying to bleed the system by myself lol Quote Share this post Link to post Share on other sites
antil33t 90 Report post Posted October 1, 2014 Buy a one man bleeder from ripco for like $10. Quote Share this post Link to post Share on other sites
bradi65 4 Report post Posted October 1, 2014 Buy a one man bleeder from ripco for like $10. Damm wish i looked at this earlier spent about 30min last night pumping the clutch and ramming a golf club between it and the seat and lots of back and forth, i might go get one anyway don't think i got all the air out, Cheers ! Quote Share this post Link to post Share on other sites
Nobimmer 694 Report post Posted October 1, 2014 Mates, neighbours, cats etc work well for bleeding clutches. Quote Share this post Link to post Share on other sites
e30ftw 433 Report post Posted October 1, 2014 Fastest way solo I found was to have the slave off the gearbox, hold it upside down. undo the bleed screw, push the rod right in, tighten it up then let the piston push back out. It will draw more fluid down through the system each time. You do it like 3 times and it starts gushing without bubbles, then you know your done. 1 Quote Share this post Link to post Share on other sites
