scottharvey 60 Report post Posted September 27, 2014 Looking at buying a pedal box the one I got won't work as doesn't have clutch pedal unless someone has just a clutch pedal sitting around Quote Share this post Link to post Share on other sites
SIR E30 68 Report post Posted September 28, 2014 (edited) Do your research before making dumb threads. You need a manual pedalbox to make this work. Just like almost every other car in the world. They are hard to come by on their own and are worth more than the shitty springs you put in the rear of your car. Keep saving and stop taking shortcuts. Edited September 28, 2014 by SIR E30 Quote Share this post Link to post Share on other sites
polley 916 Report post Posted September 28, 2014 (edited) You can fit just the clutch pedal to the auto pedal box. You need the pedal, springs, and longer bolt. Edit: original bolt might already be long enough. Been a long time since I've done it. But I've always done it by just adding the extra pedal and master cylinder. Swapping the whole pedal box is a pita. Edited September 28, 2014 by polley Quote Share this post Link to post Share on other sites
scottharvey 60 Report post Posted September 28, 2014 Yeh the one thing I don't have on mine is the clutch pedal got told by skids on here when he sold it to me I could use the original auto brake pedal in place Quote Share this post Link to post Share on other sites
e30ftw 435 Report post Posted September 28, 2014 Then what would you use for a brake pedal? Quote Share this post Link to post Share on other sites
yng_750 247 Report post Posted September 28, 2014 Then what would you use for a brake pedal? The sunvisor. What else???. 1 Quote Share this post Link to post Share on other sites
