Arma 134 Report post Posted November 2, 2014 Is it recommended to flush with new brake fluid after new pads are installed? What if only the front or only the back pads are changed? Does it matter? Quote Share this post Link to post Share on other sites
yng_750 247 Report post Posted November 2, 2014 Nothing to do with pads but recomended to change every two years. Just convieniant while the brakes are being done. 1 Quote Share this post Link to post Share on other sites
Arma 134 Report post Posted November 2, 2014 Ok cool, thanks Jason. Quote Share this post Link to post Share on other sites
E30 325i Rag-Top 3043 Report post Posted November 3, 2014 Personally I would just give them a good bleed when doing the pads. Chances are the fluid level will be pretty high once you have pushed the pistons back in to make room for the new pads, so bleeding a bit out while your there is no big deal. Quote Share this post Link to post Share on other sites
B.M.W Ltd 951 Report post Posted November 3, 2014 Never push brake fluid back through a ABS brake system. Bleed it out through the bleed nipple when compressing the piston. 1 Quote Share this post Link to post Share on other sites
dr_kahu 8 Report post Posted November 3, 2014 Jacking the thread but do wear sensors need to be replaced aswell or is it again more of a covenience/while-im-at-it type of thing? Quote Share this post Link to post Share on other sites
yng_750 247 Report post Posted November 3, 2014 I think they need doing if they wore down enough to activate. Could be wrong though Quote Share this post Link to post Share on other sites
B.M.W Ltd 951 Report post Posted November 3, 2014 I think they need doing if they wore down enough to activate. Could be wrong though Correct 1 Quote Share this post Link to post Share on other sites
kiwi535 538 Report post Posted November 3, 2014 brake fluid absorbs moisture from the atmosphere.It can absorb so much moisture it can cause pockets of steam in a hot system,and or start corrosion of brake components.Thats why you need to replace it every two years max.Any brake work is an good excuse to get rid of the old stuff 1 Quote Share this post Link to post Share on other sites
Arma 134 Report post Posted November 3, 2014 I think they need doing if they wore down enough to activate. Could be wrong though Yeah. My front sensor was fine so just re-used mine. I bought new rear sensor because I felt so sure it would be worn, but it seemed perfectly fine too. So now I have a spare sensor. Quote Share this post Link to post Share on other sites
aja540i 1925 Report post Posted November 4, 2014 The sensors will onlyneed replacing if they have worn through enough to activate the warning light on the dash, no light means the sensors can be re-used. As above replacing the fluid is a 2 yearly job, regardless of kms. 1 Quote Share this post Link to post Share on other sites
