Lucan 196 Report post Posted January 27, 2015 For Sale: $1400 for BS members 18x9.5 +25 M-Parrallels Near New Tyres Machined out to suit larger E39 CB Only a small scuff on one wheels otherwise mint. Listed on Trademe but can't link? Cheers, Lucan Quote Share this post Link to post Share on other sites
handgrenade 189 Report post Posted January 27, 2015 Any more machining to help it fit a e36 ? Quote Share this post Link to post Share on other sites
Gaz 1075 Report post Posted January 27, 2015 Any more machining to help it fit a e36 ? Doesn't need any more machining instead hub rings as e36 centre bore is smaller than e39 Quote Share this post Link to post Share on other sites
Tristan 338 Report post Posted January 27, 2015 Adeeb...! 1 Quote Share this post Link to post Share on other sites
handgrenade 189 Report post Posted January 28, 2015 Doesn't need any more machining instead hub rings as e36 centre bore is smaller than e39I mean offset wise to fit an e36 Quote Share this post Link to post Share on other sites
Gaz 1075 Report post Posted January 28, 2015 I mean offset wise to fit an e36 Ah - well they will fit if you run 225/35 tyres, roll the guards and a little camber. I've got 18.9.5 et21 on the rear of my wagon all good. Having said that, I believe that the m3 evo rear subframe is slightly wider than a normal e36 - could be wrong though. Quote Share this post Link to post Share on other sites
euroriffic 630 Report post Posted January 28, 2015 I've got 18x9 et22 on the rear of mine with a 225/40 with only really the the lips rolled and have a bit of a rub but nothing too bad. Doesn't rub with the 17x8 et20 245/40 Quote Share this post Link to post Share on other sites
