chiz 3 Report post Posted May 20, 2015 Just need an empty casing or full gearbox which is stuffed which has the right bellhousing for fitting to an M10 motor. Paul Chisholm ,chisholm@callplus.net.nz, 0274501711 Quote Share this post Link to post Share on other sites
2002 1 Report post Posted May 20, 2015 Are you going to do a gearbox swap on the 2002?. If you grab an automatic from an early E30 318 (with M10) you can unbolt the bell housing from that and it becomes a good start for gearbox swap. Quote Share this post Link to post Share on other sites
CamB 48 Report post Posted May 20, 2015 If you can't find an auto, try offering someone with a 4spd on trademe $50 for one. I sold 2x for $100 about 5 years ago I think. They're worthless. Very interested to know what you are planning to put on there. I am not hopeful for the lifespan of the E30 318i Getrag 240 in mine once (if?) I ever start driving it with the turbo. Craig (the poster above me) did a good job getting a Ford box in his, but I am not sure they're strong enough for my aspirations either. Quote Share this post Link to post Share on other sites
aja540i 1905 Report post Posted May 20, 2015 Im pretty sure i still have an e21 4 speed lying around in storage somewhere if you are still looking. 1 Quote Share this post Link to post Share on other sites
2002 1 Report post Posted May 21, 2015 Hey Cam, how about a Tremac / Borg- Warner T5 ?. Lots of donor cars (http://en.wikipedia.org/wiki/Borg-Warner_T-5_transmission) and lots of close ratio gear sets available. You can go to about 190 Hp with the Type 9 I used, or 250 Hp with the heavy duty Quaffe kit. BTW - I finally got a close ratio Quaffe kit into mine, it's awesome. Quote Share this post Link to post Share on other sites
CamB 48 Report post Posted May 21, 2015 Yeah - it looks like once you start cutting the tunnel that a T5 is a pretty cost effective option as you can get all manner of decent gear kits out of the US. I'd like to see +/-300hp (seems achievable for 2000cc turbo), so not sure how long a (reasonably expensive) HD-equipped Type 9 will last. So, as I can't find a G260 in M10/M30 fit (which is easily strong enough), I've resolved to see how I go with the G240. I am hopeful that turbo torque spread will make it less critical to have close ratio. Quote Share this post Link to post Share on other sites
Paragon 14 Report post Posted May 22, 2015 Where are the close ratio kits for a T5 ? I can only find the Quaife kit. Quote Share this post Link to post Share on other sites
BM WORLD 1266 Report post Posted May 23, 2015 m30 has same bolt pattern as m10 Quote Share this post Link to post Share on other sites
CamB 48 Report post Posted May 23, 2015 Where are the close ratio kits for a T5 ? I can only find the Quaife kit. http://www.jegs.com/v/G-Force-Transmissions/468 For the "world class" version. Quote Share this post Link to post Share on other sites
