BadBm_ 3 Report post Posted May 24, 2015 So I bought a new car E90 325 It's gonna be the third time the car gonna go back into the garage to get coil pack fixed why does this happen and what can I do Quote Share this post Link to post Share on other sites
BadBm_ 3 Report post Posted May 24, 2015 It's only been just over a month Since owning this car and I am first owner in nz Quote Share this post Link to post Share on other sites
B.M.W Ltd 951 Report post Posted May 24, 2015 Change all six coils if it is a coil fault issue Quote Share this post Link to post Share on other sites
BadBm_ 3 Report post Posted May 24, 2015 Will changing 6 help every time if have had this issue the dealership has only changed the one that's buggered twice Quote Share this post Link to post Share on other sites
qube 3570 Report post Posted May 25, 2015 its not expensive and easy to do yourself. have experienced it first hand and replacing one or two is not good. change all 6 and might as well change all the spark plugs at the same time. pm me if u want more info Quote Share this post Link to post Share on other sites
BadBm_ 3 Report post Posted May 25, 2015 The dealership I bought the car from is fixing it the third time At there expense and they agreed on changing the four (they changed 2 previously) so I am happy Is it the way I drive etc or anything that makes them go or is it a just a common problem My cars only done 80,000 km Quote Share this post Link to post Share on other sites
euroriffic 619 Report post Posted May 25, 2015 Common problem, usually caused by spark plugs past their use by date. Puts extra stress on coils to compensate dud plugs causing them to burn out. Also heard once one is replaced the new one will cause the next weakest to fail so better to do all, new plugs and good to go. Went through 3 in the e46 before I replaced them all, $600 later. Free second hand ones put it off a few months tho Quote Share this post Link to post Share on other sites
