_ethrty-Andy_ 2153 Report post Posted July 11, 2015 (edited) Hey guys Ordered a clutch kit, comes with spigot bearing, which is for the much more common Getrag gearboxes. However I am using a ZF manual, which as it turns out has a different diameter on the input shaft. Getrag is 12mm where as the ZF is 15mm or 16mm (using a chinese tape measure lol) and is not compatible. 32mm Outside Diameter (Standard BMW) 10mm Width (standard BMW) 15mm Inside Diameter Anyone have a new ZF type one lying around? Don't mind driving an hour or two to pick it up, its still going to be better than 14 days behind as busy next weekend. Of course you only find out these things on a saturday when the specialists are closed lol. Or perhaps someone knows if this same manual is used in other manual cars like Volvo or Audi etc etc?? not sure if spigot bearings are same sizes with different manufacturers. Edit: Car is an E36 with M50TUB25 Cheers Andy Edited July 11, 2015 by _Ethrty-Andy_ Quote Share this post Link to post Share on other sites
E30 325i Rag-Top 3041 Report post Posted July 11, 2015 SKF not got anything suitable? Quote Share this post Link to post Share on other sites
_ethrty-Andy_ 2153 Report post Posted July 11, 2015 probably do but not open today or at least if they were they are closed by 1 Quote Share this post Link to post Share on other sites
FIAT 131R 223 Report post Posted July 11, 2015 I will have one Andy but I am not back till Tuesday avo. If you still haven'y got one I will give it to you and you can replace it. Quote Share this post Link to post Share on other sites
