darrencnz 10 Report post Posted July 15, 2015 So it looks like I need to replace the clutch in my e30, I'm running an m52b28 with a factory getrag 240. I was hoping this would last till I got a ZF gearbox and was kinda hoping to do the gearboxes/flywheel/clutch all at once but it seems it's not going to let me do that now. I don't want a factory oem replacement but I also don't wanna spend $600-$700 on a high performance one either. Would love some suggestions as to what people have either used themselves or can recommend, I don't have massive horsepower so want something that's going to handle it but not overkill Cheers Quote Share this post Link to post Share on other sites
polley 916 Report post Posted July 15, 2015 An option is to get your clutch plate re lined and pressure plate resprung. That's around the 5 to 600 dollar mark last time I had it done Quote Share this post Link to post Share on other sites
e30ftw 433 Report post Posted July 15, 2015 I used this when I had an m52 with 240 gearbox /m20 flywheel, http://www.trademe.co.nz/motors/car-parts-accessories/bmw/clutches/auction-917971060.htm Uses a Sachs pressure plate. Can't remember what the clutch disc was. Pedal is slightly harder than stock but it's a real good clutch. Took about 1000-1500kms to wear in though, used to make the car shudder when disengaging the clutch in 1st or when trying to reverse, so you need to drive it nicely for a while. Quote Share this post Link to post Share on other sites
will 169 Report post Posted July 16, 2015 Are you still using the M52B28 dual mass flywheel/clutch? Or did you fit the M20 single mass unit? Not clear from your description... Quote Share this post Link to post Share on other sites
darrencnz 10 Report post Posted July 16, 2015 Are you still using the M52B28 dual mass flywheel/clutch? Or did you fit the M20 single mass unit? Not clear from your description... No, im running a lightened m20 flywheel. Quote Share this post Link to post Share on other sites
musccoo 82 Report post Posted August 14, 2015 I used this when I had an m52 with 240 gearbox /m20 flywheel, http://www.trademe.co.nz/motors/car-parts-accessories/bmw/clutches/auction-917971060.htm Uses a Sachs pressure plate. Can't remember what the clutch disc was. Pedal is slightly harder than stock but it's a real good clutch. Took about 1000-1500kms to wear in though, used to make the car shudder when disengaging the clutch in 1st or when trying to reverse, so you need to drive it nicely for a while. Is that D1 stage 2 a good setup for m20b25 heading for turbo ~300hp? Quote Share this post Link to post Share on other sites
polley 916 Report post Posted August 14, 2015 Is that D1 stage 2 a good setup for m20b25 heading for turbo ~300hp? I used one of those originally and it let go at 5psi boost. Now using upgraded Sachs pressure plate and regular disc. No problems at 12~psi. Quote Share this post Link to post Share on other sites
