e30ftw 435 Report post Posted July 20, 2015 (edited) NOW ON TRADEME $1 RESERVE! Bump. Have alot of it on Trademe @ $1 ending tomorrow night! M52 cams http://www.trademe.co.nz/Browse/Listing.aspx?id=932524570 Bosch 413 red label DME http://www.trademe.co.nz/Browse/Listing.aspx?id=932524589 Brake Master Cylinder http://www.trademe.co.nz/Browse/Listing.aspx?id=932524573 Bosch 405 DME http://www.trademe.co.nz/Browse/Listing.aspx?id=932524592 E30 Slave http://www.trademe.co.nz/Browse/Listing.aspx?id=932535623 E46 M3 dual mass flywheel http://www.trademe.co.nz/Browse/Listing.aspx?id=932685551 Need to get rid of some of the stuff I have lying around, I'll try get pics but sh*t is all over the show atm. E30 Brake Master Cylinder - Good condition, $40 E30 325i Front Calipers, Can include discs, pads still have meat on them. $60 e30 touring rear sway bar with poly bushes - $60 e30 complete disc rear end 320i - $60 Brakes, arms, axles and subframe e30 steering rack - $50 e36 328i radiator- $40 M52b28 cams. Removed when i swapped to s52 cams. Good condition. $60 M52B28 MAF - $60 NEW M52/M50 front Vanos unit gasket (Between head and vanos unit) P/N 11361740840 $15 Bosch 405 (M50B25 NV) - $60 Bosch 413 Red label (M50B25 Vanos) - $80 M50 Intake boot, Single hole (e36?) Good condition, $25 Edited August 18, 2015 by e30ftw Quote Share this post Link to post Share on other sites
delema00 1 Report post Posted July 20, 2015 Hi. . I'll take those front poly cab if you can send to Auckland. . . Have pm Quote Share this post Link to post Share on other sites
JayCee 26 Report post Posted July 20, 2015 Could be interested in buying my old bbs from you haha, just trying to save at the moment, will hit you up when I have the cash if still available 2 Quote Share this post Link to post Share on other sites
_ethrty-Andy_ 2153 Report post Posted July 21, 2015 Could be interested in buying my old bbs from you haha, just trying to save at the moment, will hit you up when I have the cash if still available you got to buy your car back first! 1 Quote Share this post Link to post Share on other sites
e30ftw 435 Report post Posted July 23, 2015 Bump. Added a couple things. Quote Share this post Link to post Share on other sites
SIR E30 68 Report post Posted July 24, 2015 Are the 325i calipers any different to 320i units? Also, do you have 325i axles? Quote Share this post Link to post Share on other sites
e30ftw 435 Report post Posted July 25, 2015 Nah no axles, yeah the brakes should be the same. Quote Share this post Link to post Share on other sites
e30ftw 435 Report post Posted August 3, 2015 Bump - Updated. Need this stuff gone Asap, make an offer. Quote Share this post Link to post Share on other sites
agent75 37 Report post Posted August 12, 2015 Hi there. What diameter is rear sway bar? Would it fit a 318i coupe or is rear end different? Sent from my iPhone using Tapatalk Quote Share this post Link to post Share on other sites
e30ftw 435 Report post Posted August 12, 2015 Ah, can't tell you Dont have a way to measure. It was from a 320i touring. And yes should fit, they still have the mounting parts on chassis. It's only got one metal mount, you'd need another - also sway links binned. Quote Share this post Link to post Share on other sites
e30ftw 435 Report post Posted August 18, 2015 Bump. Have alot of it on Trademe @ $1 ending tomorrow night! M52 cams http://www.trademe.co.nz/Browse/Listing.aspx?id=932524570 Bosch 413 red label DME http://www.trademe.co.nz/Browse/Listing.aspx?id=932524589 Brake Master Cylinder http://www.trademe.co.nz/Browse/Listing.aspx?id=932524573 Bosch 405 DME http://www.trademe.co.nz/Browse/Listing.aspx?id=932524592 E30 Slave http://www.trademe.co.nz/Browse/Listing.aspx?id=932535623 E46 M3 dual mass flywheel http://www.trademe.co.nz/Browse/Listing.aspx?id=932685551 Quote Share this post Link to post Share on other sites
e30ftw 435 Report post Posted August 19, 2015 Last bump... Auctions closing in 1 hour Quote Share this post Link to post Share on other sites
Ahmedsinc 414 Report post Posted August 19, 2015 Any idea on shipping cost for the dual mass to Auckland? Quote Share this post Link to post Share on other sites
e30ftw 435 Report post Posted August 19, 2015 Probably close to $20. Pretty heavy. Quote Share this post Link to post Share on other sites
