gjm
3-series sway bars - specs
Apologies if this has been posted before. I had a look but didn't find anything.
This list is mainly from https://www.vorshlag.com/bars.php. I've added a couple of entries.
E46 Convertible with sport suspension has a 20mm Rear bar.
Have a look in the parts cat for the e46 range their is some six different dia's range from 22.5 to 26.5 for the front this appears to be model , engine and suspension type dependent. The rear shows two at 18 or 19 also suspension and model it does not include the M3.
Not sure if this helps but I found this list for e30's. I then got under my stock e30 320i to find it doesn't have a rear sway bar at all. So I'm on the hunt for a 14.5mm one. There's one on the front which is 18mm.
http://www.e30zone.net/e30zonewiki/index.php/Anti-Roll_Bar
