Rohil 30 Report post Posted August 4, 2015 Hey guys, Just picked up a Behr oil cooler from an E24 and wondering if anyone has ever fitted these to an E30? Importantly, will the lines fit? The part number on it is 11764581 E5 Any help would be much appreciated! Sent from my GT-I9505 using Tapatalk Quote Share this post Link to post Share on other sites
Rohil 30 Report post Posted August 4, 2015 Sent from my GT-I9505 using Tapatalk Quote Share this post Link to post Share on other sites
E30 325i Rag-Top 3034 Report post Posted August 4, 2015 The actual radiator part of the cooler can probably be made to fit, the gap where the cooler sits is pretty big on the E30 so there is room to move there. It is the lines that are more of an issue, depending on what engine you are trying to fit it up to the connections can be on different sides of the engine (M20 LHS, S14 RHS) and the gap to get them through is pretty tight. The good news though is that the pipes are interchangeable on the cooler. If it is your 323i you are trying to fit it into I do have a couple of lines off a 325i that could well work... Quote Share this post Link to post Share on other sites
B.M.W Ltd 951 Report post Posted August 4, 2015 And I have the E30 oil cooler $50 Quote Share this post Link to post Share on other sites
Rohil 30 Report post Posted August 5, 2015 And I have the E30 oil cooler $50With the lines and all?Sent from my GT-I9505 using Tapatalk Quote Share this post Link to post Share on other sites
B.M.W Ltd 951 Report post Posted August 5, 2015 I might have the lines as well, but not the thermostat oil filter housing you will need as well Quote Share this post Link to post Share on other sites
Rohil 30 Report post Posted August 5, 2015 I might have the lines as well, but not the thermostat oil filter housing you will need as wellI have that, just need the cooler and lines to finish it off. Sent from my GT-I9505 using Tapatalk Quote Share this post Link to post Share on other sites
B.M.W Ltd 951 Report post Posted August 5, 2015 If you want them for the price indicated I'll look... if not I'm not looking Quote Share this post Link to post Share on other sites
Rohil 30 Report post Posted August 5, 2015 If you want them for the price indicated I'll look... if not I'm not looking Pm'd Sent from my GT-I9505 using Tapatalk Quote Share this post Link to post Share on other sites
Rohil 30 Report post Posted August 17, 2015 The actual radiator part of the cooler can probably be made to fit, the gap where the cooler sits is pretty big on the E30 so there is room to move there. It is the lines that are more of an issue, depending on what engine you are trying to fit it up to the connections can be on different sides of the engine (M20 LHS, S14 RHS) and the gap to get them through is pretty tight. The good news though is that the pipes are interchangeable on the cooler. If it is your 323i you are trying to fit it into I do have a couple of lines off a 325i that could well work... Hey man, I am trying to mount it up to a m20b25. I am after the lines provided I can use the cooler I have. If you have the lines I'd be happy to get them provided they work for this application. Thanks for your help! Sent from my GT-I9505 using Tapatalk Quote Share this post Link to post Share on other sites
Rohil 30 Report post Posted August 24, 2015 Anyone have any e30 oil cooler lines? The ones off the E24 cooler don't have a thread, rather a flare type fitting which seems different as the oil filter housing has a thread. Sent from my GT-I9505 using Tapatalk Quote Share this post Link to post Share on other sites
Rohil 30 Report post Posted September 15, 2015 For future reference, it fits! And the title meant to say E24.... Sent from my GT-I9505 using Tapatalk Quote Share this post Link to post Share on other sites
