Cheyne_Oo 1 Report post Posted August 10, 2015 Im just wondering if any one could tell me what diff ratio I need for my manual conversion. I have a e36 328I and using a 325 getrag box i havent look into the gearing side of things, all I know is the auto diff makes the engine rev its guts out at 100km, so if anyone can give me an idea or even have one for sale of what I need it would help heaps. Quote Share this post Link to post Share on other sites
BM WORLD 1295 Report post Posted August 10, 2015 factory 328i manuals went with a 2.93 325i used a 3.15 ratio but there are also 3.07 I have 3.07 and 3,15 diffs in stock 021433600 [email protected] Quote Share this post Link to post Share on other sites
Ahmedsinc 414 Report post Posted August 10, 2015 3.07 & 3.15 will give the most economical fuel figures. 3.46 will give you a nice bump in acceleration but come at a cost to efficiency and top speed. 2.93 is too tall IMO. 3.23 however is my pick for standing acceleration, overtaking and not being impossible at 60mph. 3.07 would probably be fine with the extra torque of the M52 1 Quote Share this post Link to post Share on other sites
BM WORLD 1295 Report post Posted August 10, 2015 I use a 3.15 in my 328i about 2650rpm at 100km/h in 5th but I think I would change it if I could be bothered to a 3.07 about 2550rpm at 100km/h in 5th 1 Quote Share this post Link to post Share on other sites
Allanw 1077 Report post Posted August 10, 2015 ..... and not being impossible at 60mph. You're trying to rark up Ron, right? 2 Quote Share this post Link to post Share on other sites
allan 295 Report post Posted August 10, 2015 In the compact now have a 3.15:1 M54 b25 does a shade over 2500 at 100k 5th gear 1:1. It did have a 3.48:1 and first was useless and revved at about 3100 at 100 if that is of any help. Quote Share this post Link to post Share on other sites
Ahmedsinc 414 Report post Posted August 11, 2015 You're trying to rark up Ron, right? Moi? Facetious? Never! 1 Quote Share this post Link to post Share on other sites
Rubix 434 Report post Posted September 16, 2015 (edited) Necrobumping this thread.Converting my e36 328i shortly (aiming for this weekend).Jatco auto, likely has a 3.91 diff (as this was the factory diff for a 328i auto, but the tag is missing on mine), replacing with ZF 5 speed. From what I understand i'll likely be sitting at 3400ishRPM in 5th at 100kph with the 3.91, while I wouldn't mind this for a couple of weeks I'll likely want to have somewhat decent fuel economy in the future.I take it I'll need a medium case diff? Brent, do you happen to have any 3.15's or 3.46' in stock? Pricing? Actually using a diff ratio calculator.. 25 inch diameter tyre (rounded up from 24.972) - (225/45/17 tyre on 17" rim)3.91 diff ratio62mph/100kph = 3258rpm? Surely this can't be right? Seems awfully low rpm, I'd almost be happy with it if that's the case o.o Edited September 17, 2015 by Rubix Quote Share this post Link to post Share on other sites
Ahmedsinc 414 Report post Posted September 17, 2015 Cruising revs don't tell the entire story. 3.91 final drive will turn your 5 speed into a 4 speed as first gear will be uselessly short. Unless you do a lot of burnouts, in which case stick with the 3.91 Given the M52B28 develops ok torque I'd look for a 2.93 or 3.07, definitely wouldn't bother going higher than 3.23. M50s benefit from the shorter gearing to mask our lack of bottom end torque, not so much of a problem for the B28. Yip, medium case is what you need. Complete pain in the ass job but it utterly transforms the car, you won't regret the swap Quote Share this post Link to post Share on other sites
BM WORLD 1295 Report post Posted September 17, 2015 328i jatco auto , normally a 3.46 diff 3.07 will do nicely call me 021433600 http://members.dodo.com.au/~wawawa/revs.htm Quote Share this post Link to post Share on other sites
Rubix 434 Report post Posted September 17, 2015 (edited) 328i jatco auto , normally a 3.46 diff 3.07 will do nicely call me 021433600 http://members.dodo.com.au/~wawawa/revs.htm It's an e36, are you sure it came with a 3.46? Can't find anything anywhere to support that. EDIT: Actually you may be right..According to this: http://www.driftworks.com/forum/technical/42834-bmw-e36-differential-ratio-got-screwed-up.html Jap 328i's have a 3.46? this definitely correct? Edited September 17, 2015 by Rubix Quote Share this post Link to post Share on other sites
BM WORLD 1295 Report post Posted September 17, 2015 std spec for that type http://bmwfans.info/parts-catalog/E36-Cabrio/Europe/328i-M52/R-A/1996/browse/rear_axle/rear_axle_drive/ wrecked about a million of these cars , and that's what most of them have , unless they have been swapped out etc a lot of other info out there relates to usa spec ... Quote Share this post Link to post Share on other sites
