trip3
Wanted to borrow - timing light
For a Ti ??? What are you trying to do or check??
Early M30 rebuild. Wanting to set the timing...
That sounds like an interesting project (if you are putting it in the ti that is :P )
Lol... Yeah would be... E28 build though :)
Nice, what model? You should stick it in your car list on your profile.
I have a timing light with all the necessary, but am too far away and would have to fight off the multitude of spiders that have made home in the dark beyond of my unused equipment cupboard.... :P
in any case, I would just set the timing by ear, advance it till you get pinking and then back it off till you get no more pinking under load in 4th/5th (your choice). Make sure the vacuum and centrifugal advance/retard systems are all functioning properly before doing the timing-lube the mechanical one while you are at it.
The standard timing setting is quite conservative, takes into account the crappy fuels that were available back then- you can get a far better result with more advance and better fuel (95 etc).
