Jimbob789 1 Report post Posted September 19, 2015 So my 328i e36 has been sitting around for a couple of months, I went to start it yesterday, let it run for about 10 mins then all of a sudden, there was a massive bang and steam pouring from the gaps around the bonnet! Pulled up the bonnet and the top radiator hose has a massive hole in and coolant gone everywhere!!! Before I replace the pipe, I obviously need to find out the root cause. Any ideas? Has never overheated or anything since ownership btw. Quote Share this post Link to post Share on other sites
_ethrty-Andy_ 2153 Report post Posted September 19, 2015 has the fan been hitting it Quote Share this post Link to post Share on other sites
Jimbob789 1 Report post Posted September 19, 2015 That what I first thought but it doesn't look like it, there's a rather large gap between + the hole is on the top. Could it just be wear? Quote Share this post Link to post Share on other sites
polley 916 Report post Posted September 19, 2015 Old hose, or over pressurised. Or combination of both. Quote Share this post Link to post Share on other sites
aja540i 1925 Report post Posted September 19, 2015 Looks like the inside of that hose is perished quite badly, they do that with age, unfortunately the others in your cooling system the same age might not be far behind, good time to do some preventative maintenance! Quote Share this post Link to post Share on other sites
trottsky 24 Report post Posted September 19, 2015 If you can afford it, get a new water pump, thermostat and housing, alloy radiaor with combined header tank and a full hose set. It sounds like overkill but otherwise you'll be chasing leaks/issues until you've replaced it all anyway! Quote Share this post Link to post Share on other sites
Ahmedsinc 414 Report post Posted September 19, 2015 Lol, that's a good-un! Well done, should souvenir it for the shed wall But seriously, take it as an omen that your cooling system needs an overhaul. Makes for expenses that you probably hadn't budgeted on, but replacing a few hoses and a radiator is still easier than a head job / engine swap 1 Quote Share this post Link to post Share on other sites
Jimbob789 1 Report post Posted September 19, 2015 Thanks guys, will take your advise and replace the whole system, after all it is a project car ? Quote Share this post Link to post Share on other sites
