musccoo 82 Report post Posted September 22, 2015 (edited) Anyone run 15x7 et24 euroweaves with rx7 calipers? Tryna figure out what size spacers I need and wondering if I can get away with 5mm + grinding the fluid passage down...10mm spacers would clear but heard bad things about 10mm spacers.. Edited March 9, 2017 by musccoo Quote Share this post Link to post Share on other sites
Silver Fox 43 Report post Posted September 22, 2015 We use them on the race car. No spacers needed. Did you get the kit from the States it has all the bits you need. 1 Quote Share this post Link to post Share on other sites
musccoo 82 Report post Posted September 22, 2015 Really? Yea I have the fancy bracket and line adaptors. I tried to do a test fit and it was hitting the knob when I stacked 5mm of washers on the wheel bolt threads Sent from my HTC One M9 using Tapatalk Quote Share this post Link to post Share on other sites
musccoo 82 Report post Posted September 24, 2015 David you must have different wheels?? as I just measured the clearance from wheel hub to spoke and from disc hub to end of calliper and theres no way it can clear without a spacer. Looks like the minimum I could get away with is a 6mm spacer with grinding down 3mm of the fluid passge Quote Share this post Link to post Share on other sites
Red Dwarf 136 Report post Posted September 25, 2015 (edited) The website guide says 15x7 Basketweave (ET25): "5mm spacer, light grinding"... which is as good a place as any to start Edited September 25, 2015 by Red Dwarf Quote Share this post Link to post Share on other sites
Silver Fox 43 Report post Posted September 25, 2015 Will look over the weekend and get back to you Quote Share this post Link to post Share on other sites
musccoo 82 Report post Posted September 25, 2015 Will look over the weekend and get back to you Thanks David. The website guide says 15x7 Basketweave (ET25): "5mm spacer, light grinding"... which is as good a place as any to start Yeah I seen this, just found it hard to believe...think 'light grinding' is an understatement haha, but will give it a go this weekend. Quote Share this post Link to post Share on other sites
musccoo 82 Report post Posted September 26, 2015 Just been doing some grinding and trying to fit with 6mm of spacers, even then it still doesn't clear and with 5mm spacer the bump would have to be dead flush. I don't understand how the website says 5mm....my euroweaves and these brakes arnt meant to be Quote Share this post Link to post Share on other sites
Red Dwarf 136 Report post Posted October 2, 2015 You sure the calliper brackets are the right way round? Quote Share this post Link to post Share on other sites
musccoo 82 Report post Posted October 2, 2015 Yeah pretty sure I do, I tried the other way just to be sure and it makes it worse. Will look over the weekend and get back to you What was the verdict David? Quote Share this post Link to post Share on other sites
Red Dwarf 136 Report post Posted October 3, 2015 (edited) The wagon's here at the moment... you're welcome to wander over to have a look at the set-up if you want...I've had genuine basketweaves on it and don't recall any clearance issues... Bring a wheel and we can throw it on to see of there's a difference! Edited October 3, 2015 by Red Dwarf Quote Share this post Link to post Share on other sites
musccoo 82 Report post Posted November 10, 2015 Ready for some track action... 1 Quote Share this post Link to post Share on other sites
duvey 245 Report post Posted November 11, 2015 (edited) Did you ever get this to work under your euroweaves with or without spacers? Edited November 11, 2015 by duvey Quote Share this post Link to post Share on other sites
musccoo 82 Report post Posted November 11, 2015 (edited) Lol...I tired.Got some 10mm hubcentric spacers - brand SCC from schmiedmann.com, put them on for test fit, something seemed odd...took wheel off again and to my surprise...hubcentric spacer no longer hubcentric...I'm gonna try ECS tuning 10.5mm hubcentric spacers they look like the goods. But apart from that..I shaved half the fluid passage down and 10mm spacers were only *just* enough to clear the caliper with weaves. So when the guys website says weaves + 5mm spacer, I call bull..Here you can kinda see how much I took off the knob Edited November 11, 2015 by potatomash Quote Share this post Link to post Share on other sites
duvey 245 Report post Posted November 11, 2015 Noticed any effect on handling with the spacers? Quote Share this post Link to post Share on other sites
musccoo 82 Report post Posted November 11, 2015 Well I didn't get a chance to try it out cause they broke. I need to order new ones. Cant see any reason it would be a problem though Quote Share this post Link to post Share on other sites
duvey 245 Report post Posted November 11, 2015 Well I didn't get a chance to try it out cause they broke. I need to order new ones. Cant see any reason it would be a problem though Whoops sorry, didn't realise they hadn't arrived yet. Let me know how you go with those. Cheers. Quote Share this post Link to post Share on other sites
musccoo 82 Report post Posted December 18, 2015 Im running 12.5mm spacers with the weaves and they are all good. Offset looks nice too Quote Share this post Link to post Share on other sites
duvey 245 Report post Posted December 18, 2015 Im running 12.5mm spacers with the weaves and they are all good. Offset looks nice too Got any pictures? Quote Share this post Link to post Share on other sites
musccoo 82 Report post Posted December 18, 2015 (edited) I had to have the inside of the spacer machined ~1.5mm to fit over the small bit of hub that sticks out of the corrado rotor due to it sitting 1mm further back than an e30 rotor. Cheers to Andrew (curryinahurry) for helping me out with that Edited December 21, 2015 by potatomash 1 Quote Share this post Link to post Share on other sites
E30 325i Rag-Top 3041 Report post Posted December 20, 2015 I ended up with the same as you, 10mm spacers and a bit shaved off the bump on the caliper. Only just cleared as well.. 2 Quote Share this post Link to post Share on other sites
darrencnz 10 Report post Posted February 20, 2016 (edited) About to do this mod on my car, got myself some FD series 6 calipers, have heard people say they are different, but after some research, it appears that they are dimensionally identical and i figured its best to go with the newest parts available anyway. They look quite nice too once the Mazda logo is removed... Edited February 20, 2016 by darrencnz 1 Quote Share this post Link to post Share on other sites
Cammsport 391 Report post Posted March 8, 2017 Disturbing an old post i know bit I was wondering if you RX7 BBK veterans would be able to give me a hand. I've bought some S4 calipers recently to do the conversion. I'm now starting to wonder if my BBS RSs that I'm building up will clear. Before I go ahead and machine the dog bones and purchase new lips, I was wondering if someone could measure from the face of the mounting hub to the outer part of the caliper to gauge clearance. Can draw a pic to clarify if necessary. Thank you for any help provided, much appreciated. Quote Share this post Link to post Share on other sites
E30 325i Rag-Top 3041 Report post Posted March 8, 2017 Easy enough for me to whip a wheel off and have a measure up for you. If you have a pic to show exact dimension it could be helpful. Quote Share this post Link to post Share on other sites
musccoo 82 Report post Posted March 9, 2017 You'll need spacers for sure, just depends what size...I have 30mm spacers to clear my Volk 3 piece by a credit cards width haha. Quote Share this post Link to post Share on other sites
