charles28 141 Report post Posted October 9, 2015 Hi Guys, I'm having an odd problem. I can have my heater set on cold for both driver and passenger sides and intermittently I get hot air coming out of the drivers side vents. (happens about 3/5 times when I use the car now). It doesn't do it every time, if I have the A/C on the air is cold out of all the vents, however I usually just have it turned off with just the fan running bringing cooler air in from outside. I thought heater valve, but if it was this, would it be intermittent ? Quote Share this post Link to post Share on other sites
aja540i 1909 Report post Posted October 10, 2015 Mine did something similar, i replaced the rubber diapraghms in the heater control valve and it fixed it right up. Quote Share this post Link to post Share on other sites
charles28 141 Report post Posted October 10, 2015 Mine did something similar, i replaced the rubber diapraghms in the heater control valve and it fixed it right up. Thanks, will give that a go, have ordered the repair kit Quote Share this post Link to post Share on other sites
Allanw 1078 Report post Posted October 11, 2015 Clean out the sample inlet vents in the AC control too, and don't put hot/cold drinks near them (tricks the AC - sh*t design!) Quote Share this post Link to post Share on other sites
