charles28
e39 Climate Control issue
Hi Guys,
I'm having an odd problem.
I can have my heater set on cold for both driver and passenger sides and intermittently I get hot air coming out of the drivers side vents. (happens about 3/5 times when I use the car now).
It doesn't do it every time, if I have the A/C on the air is cold out of all the vents, however I usually just have it turned off with just the fan running bringing cooler air in from outside.
I thought heater valve, but if it was this, would it be intermittent ?
Mine did something similar, i replaced the rubber diapraghms in the heater control valve and it fixed it right up.
Thanks, will give that a go, have ordered the repair kit
Clean out the sample inlet vents in the AC control too, and don't put hot/cold drinks near them (tricks the AC - sh*t design!)
