MD13 562 Report post Posted October 10, 2015 So I tried installing a sub in my e46 today. It came with an alpine h/u and alpine amp in the boot but the sub was absent. Spent all day checking the boot wiring and mounting the amp more securely. Test it and set the gain all good but time consuming so far. Then I start it and something is making a motor noise in the dash - either the h/u or the climate control unit. Keeps going even when the car is off and the key removed. To get it to stop I have to disconnect the battery... I did not touch anything in the dash. All work was done in the boot... Ideas? Quote Share this post Link to post Share on other sites
zero 1162 Report post Posted October 10, 2015 So did you install a sub? Just trying to understand the variables. Quote Share this post Link to post Share on other sites
aja540i 1925 Report post Posted October 10, 2015 Does the headunit have a cooling fan in it? Quote Share this post Link to post Share on other sites
MD13 562 Report post Posted October 11, 2015 Not sure - has crossed my mind... Have tried turning the h/u amp off to no affect. Have disconnected the amp turn on lead and rca's to no affect. Sigh. H/u out next. Quote Share this post Link to post Share on other sites
zero 1162 Report post Posted October 11, 2015 Sounds like this problem; http://www.bimmerfest.com/forums/showthread.php?t=523898 Because you are doing audio stuff you are more likely to hear these other noises as u are listening more intently. Quote Share this post Link to post Share on other sites
MD13 562 Report post Posted October 11, 2015 The climate control unit! Pulled it out, retested and no noise. Plugged it back in but hanging loose and the little fan in the back is noisy. There seems to be some other noise behind the dash cluster also... This only stays for 5 seconds or so then stops. So possibly the resistor you've mention Zero or this: http://forum.e46fanatics.com/showthread.php?t=298527 Relief thinking I haven't f**ked this up but annoying too! Quote Share this post Link to post Share on other sites
zero 1162 Report post Posted October 11, 2015 The resister is a common fault, and not too hard to fix. Good luck. Quote Share this post Link to post Share on other sites
