Jacko 2265 Report post Posted October 27, 2015 Anyone come across this before? Fault code logged - Communication error with LH mirror, thought it was erroneous, have just figured out its not though. Every once in a while the dip funtion when sticking car in reverse doesnt work. Im guessing its a wiring fault, dirty plug, or something. Wondering if anyone has any clues on where to start looking? Google isnt helping me, so im guessing its not common. Quote Share this post Link to post Share on other sites
aja540i 1922 Report post Posted October 27, 2015 Its not because the adjuster selector switch is in the wrong position? It will only dip when the switch is on one side , not sure which side it is though Quote Share this post Link to post Share on other sites
Matth5 471 Report post Posted October 29, 2015 (edited) Its not because the adjuster selector switch is in the wrong position? It will only dip when the switch is on one side , not sure which side it is though Have to have the right (drivers) one selected. Or else the left one doesn't move, I presume in case the driver wants to adjust it. But the fault code in this case indicates there is a problem here... Edited October 29, 2015 by Matth5 Quote Share this post Link to post Share on other sites
