kdalton
Yellow sport adjustable
Sorry if this is a dumb question but I installed yellow speed adjustable suspension on my e36 and was wondering how I can adjust the rears?? It isn't sitting low at all in the rear with the spring adjuster at the very bottom. Is it legal if I remove the adjuster and just use the spring? (It's sitting higher then it was with super lows)
aslong as the spring is still captive at full droop then you will be fine but you do find sometimes that they do not lower enough and you may have to go back to your super lows
Sweet I'll see how low it sits tonight.
I know my BC Golds came with a locator for the spring to hold it in place without the adjuster. Does it have one of those?
