Aaron320iSmith 0 Report post Posted January 2, 2006 Can i ad foggys to my 85 320i nz new? Quote Share this post Link to post Share on other sites
topless 14 Report post Posted January 2, 2006 Wiring is normally there to add front fogs. Check under dash on loom to light switch for a rectangular plug. If it is there you will find the foglight plugs in the engine bay behind the headlights on both sides. Pic shows foglight switch plug under dash and light plug (arrowed) in engine bay. Quote Share this post Link to post Share on other sites
petone 0 Report post Posted January 2, 2006 you also need to add the relays and fuses. The plugs for the foglight switch might be slightly different, nothing some pliers can't fix though. Quote Share this post Link to post Share on other sites
topless 14 Report post Posted January 2, 2006 you also need to add the relays and fusesyea, if you find the wiring is there come back and will give you all the details how to make them work. Quote Share this post Link to post Share on other sites
Aaron320iSmith 0 Report post Posted January 2, 2006 Yep its all there Quote Share this post Link to post Share on other sites
topless 14 Report post Posted January 2, 2006 (edited) you will need the dash switch, there are 2 types, one for just front fogs and one for front/rear fogs. Also you will need a relay which has double contact points, i.e. both an 87 and an 87b contact. Photo shows both dash switches, double on left and single on right with rear view of both. The relay pic shows the pin config needed. Refer to pic of fuse box. Relay to go in position K8 (circled), and you will need two 7.5A fuses and put them in positions 29 and 30 as circled. Of course you will need the foglamps too... Edited January 2, 2006 by topless Quote Share this post Link to post Share on other sites
Aaron320iSmith 0 Report post Posted January 3, 2006 Switch is already there, wheres the best place to get the fogys from? repco? Cheers dude thanks for the help Quote Share this post Link to post Share on other sites
Guest Andrew Report post Posted January 4, 2006 Switch is already there, wheres the best place to get the fogys from? repco? Cheers dude thanks for the help a BMW wrecker Quote Share this post Link to post Share on other sites
OLLIE 27 Report post Posted January 4, 2006 you can custom fit hella fogs if you like Quote Share this post Link to post Share on other sites
