Garryg 5 Report post Posted December 7, 2015 Hi All, I have been trawling through pages and pages of info on Google... There are several posts in various forums saying that Bluetooth is standard in models produced after 2004...is this correct? If so, how do I set it up as currently it doesn't show on the idrive. Cheers Quote Share this post Link to post Share on other sites
beemn 50 Report post Posted December 7, 2015 if not on the idrive then not installed. check your build sheet Quote Share this post Link to post Share on other sites
Breaker 980 Report post Posted December 7, 2015 Correct, likely not installed standard, most weren't. As Milan check your build sheet at BMWVIN.com Added Bluetooth to ours it was a hefty $1600 for that alone, then radio and nav on top to convert from Jap version Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted December 7, 2015 Talk to Joe @ Eurosurgeon in Penrose Quote Share this post Link to post Share on other sites
Matth5 471 Report post Posted December 7, 2015 (edited) Not standard and the cost of getting BT with music (yes, there's a version that does calls only) added to an iDrive BMW is ridiculous. If you have an Aux input, you can get a BT Aux adapter for less than $50. Edited December 9, 2015 by Matth5 Quote Share this post Link to post Share on other sites
Garryg 5 Report post Posted December 8, 2015 Correct, likely not installed standard, most weren't. As Milan check your build sheet at BMWVIN.com Added Bluetooth to ours it was a hefty $1600 for that alone, then radio and nav on top to convert from Jap version Just checked the build sheet....not fitted :-( Thanks All. Quote Share this post Link to post Share on other sites
