eliongater 718 Report post Posted December 15, 2015 Interested in doing converting my m20b27 to motronic 1.1. So I need the following parts: Crank Position Sensor & Bracket Toothed crank wheel Engine bay loom Cylinder Identification Sensor Oil Level Sender Oil Pressure Switch And probably an ECU, but I haven't decided what I'm doing ECU wise yet Quote Share this post Link to post Share on other sites
BM WORLD 1295 Report post Posted December 16, 2015 if you go down this route , you will most likely be needed a custom remap done to get it to run right Quote Share this post Link to post Share on other sites
HELLBM 1674 Report post Posted December 16, 2015 What you need is the motronic 1.3 conversion. Have kits available @ Hellbm. Quote Share this post Link to post Share on other sites
