WYZEUP 283 Report post Posted December 22, 2015 i am currently in the process of possibly purchasing a m60 engine, the owners says he thinks it is a m60b40 but cant 100% confirm this, is there any signs or markings i can get him to check for to confirm the engine assembly is as he states it is. Cheerz guys Quote Share this post Link to post Share on other sites
Michael. 2313 Report post Posted December 22, 2015 (edited) Look inside to see if has double chain timing setup, just open the oil cap. Anything date stamped like plastic covers would tell you too. Edited December 22, 2015 by Michael. Quote Share this post Link to post Share on other sites
will 169 Report post Posted December 22, 2015 Look inside to see if has double chain timing setup, just open the oil cap. Anything date stamped like plastic covers would tell you too. M60B30 looks identical so beware.. If you have the ECU, it will have the VIN on it, use that to pull up the build sheet, it will tell you what motor it is. Otherwise the code alongside the engine number will tell you the capacity. 2 Quote Share this post Link to post Share on other sites
BM WORLD 1294 Report post Posted December 22, 2015 stamp numbers on the side of the block lhs I think by mounts Quote Share this post Link to post Share on other sites
