musccoo 82 Report post Posted January 17, 2016 Going to put e90 drophats in my front struts this weekend, what rubber spring pad do i want? 31 33 1 128 523 is 3mm for e30 31 33 1 128 522 is 9mm for e30 or 31 33 6 767 500 is for the e90 or does it not matter? Quote Share this post Link to post Share on other sites
_ethrty-Andy_ 2144 Report post Posted January 18, 2016 John get in here Quote Share this post Link to post Share on other sites
duvey 245 Report post Posted January 18, 2016 I re-used the original e30 ones. No issues, fit nicely. 1 Quote Share this post Link to post Share on other sites
musccoo 82 Report post Posted January 18, 2016 I would reuse but my ones are f'd. Can I just roll without them all together? Sent from my HTC One M9 using Tapatalk Quote Share this post Link to post Share on other sites
_ethrty-Andy_ 2144 Report post Posted January 18, 2016 I would reuse but my ones are f'd. Can I just roll without them all together? Sent from my HTC One M9 using Tapatalk Have seen a few over the years that damage the strut and push out at the bottom of the spring purch from running with no pad. then rust gets in there not a good look. probably want thinnest you can get otherwise will counteract the whol point of the lower tophats Quote Share this post Link to post Share on other sites
e30ftw 433 Report post Posted January 18, 2016 I didn't run any 1 Quote Share this post Link to post Share on other sites
musccoo 82 Report post Posted January 18, 2016 (edited) Hmm. Does anyone have a spare? Might just wing it if not cause can't find any locally Edited January 18, 2016 by mulanimal Quote Share this post Link to post Share on other sites
NVADER 54 Report post Posted January 18, 2016 (edited) I used the factory pads. The e90 drop hats are exactly the same diameter just slightly higher.It's a wof requirement to have them in there and in good condition but a lazy inspector may not notice they're missing if he/she never saw them there before Edit: I'll check my parts car for you tonight. They're also on ebay for next to nothing brand new Edited January 18, 2016 by NVADER Quote Share this post Link to post Share on other sites
musccoo 82 Report post Posted January 18, 2016 (edited) Thanks man.Mmm wof not a problem lol. Mine breezed through with rx7 brakes and wheel spacers like they were straight out of the factory Edited January 18, 2016 by mulanimal Quote Share this post Link to post Share on other sites
Forrest 35 Report post Posted January 19, 2016 I used road bike inner tubes pulled over the first coil on each side of the spring. Previously used no pads in the E30 and had no issues at WOF time as long as the springs are captive. 1 Quote Share this post Link to post Share on other sites
_ethrty-Andy_ 2144 Report post Posted January 19, 2016 never heard of spring pads being a requirement. they are only for comfort and to keep the noise down etc. but i could be wrong. Quote Share this post Link to post Share on other sites
musccoo 82 Report post Posted January 19, 2016 I used road bike inner tubes pulled over the first coil on each side of the spring. Previously used no pads in the E30 and had no issues at WOF time as long as the springs are captive. Well that's a good idea, I got plenty of them lying around.. Quote Share this post Link to post Share on other sites
musccoo 82 Report post Posted January 24, 2016 Well. I feel like these look no different to the e30 ones lol Quote Share this post Link to post Share on other sites
NVADER 54 Report post Posted January 26, 2016 Andy - OP is slow to pick up on your subtle correction that these are generally referred to as "Top hats" not "" Drop hats"" . The difference in pad thickness is to enable you to level the suspension to within spec. To do this you first measure the ride height with a pad in there (usually the 3mm ) and then work out which to use where. The other option is to plasti-dip the first wind on each end - but pads are nicer - you can make your own out of urethane sheet. P.S Andy it's a spring 'perch' -------- "purch" is a colloquial term meaning 'to buy' or make a purchase. :wacko: :wacko: :wacko: Actually, people do commonly refer to these as drop hats. That's what they're advertised as when they're being sold as E30 items probably to differentiate them from the factory top hats. http://store.garagistic.com/BMW-E30-front-drop-hats-31336764093-E90?search=drop%20hats And yeah Andy - they're not specifically mentioned and I've passed warrants without my lowers in the rear but technically you're removing a factory suspension component. Comes down to whether or not the inspector knows that they're supposed to be there in the first place I guess. Quote Share this post Link to post Share on other sites
_ethrty-Andy_ 2144 Report post Posted January 27, 2016 Actually. Ron you are wrong and I did a typo earlier. top hat is the spinny piece at the top. the upper strut mount I actually typo'd when i said that before. the drop hat is the top spring purch (or perch) to prevent the spring from toching the spinning top hat. which when using an E90 one on an E30 setup lets the spring sit up closer to the top hat. 1 Quote Share this post Link to post Share on other sites
e30ftw 433 Report post Posted January 27, 2016 Top hat / Drop hat refers to the same thing (The upper spring perch (shaped like a hat)), People were originally selling them off as drop hats for an e30 until someone figured out they were just OEM e90 top hats being sold as e30 "drop hats", name coming from the fact they "dropped" the car slightly. Piece of useless e30 history for ya'll Quote Share this post Link to post Share on other sites
