M M 250 Report post Posted February 18, 2016 (edited) I'm doing a B35 swap into my eta e28 so I believe I need the e28 M30 motor mount brackets. Anyone have some they can sell me? These are the part numbers: Left mount - 11 81 1 175 591 Right mount (rectangle type) - 11 81 1 175 592 Edited February 18, 2016 by M M Quote Share this post Link to post Share on other sites
eliongater 718 Report post Posted February 19, 2016 b35 or b34? b35 is unlikely to have the right bolt holes for the factory e28 m30 mounts. http://www.mye28.com/viewtopic.php?t=60306 http://www.bmw-stuff.com/proddetail.asp?prod=m30r Quote Share this post Link to post Share on other sites
eliongater 718 Report post Posted February 19, 2016 Have you already got an engine? Becuase I'm pretty sure the best option is to get a b34 (no custom mounts needed and higher compression) and then use a b35 loom and ECU. Quote Share this post Link to post Share on other sites
M M 250 Report post Posted February 19, 2016 I've got the B35 and I'm going with that, I am aware of the difference in bolt pattern but from what I've found the easiest option is the get the B34 E28 mounts and then get the adapters. Otherwise I will make fully custom mounts if no one has any. Quote Share this post Link to post Share on other sites
BM WORLD 1275 Report post Posted February 19, 2016 probably have some from e28 or e24 etc . 021433600 [email protected] Quote Share this post Link to post Share on other sites
M M 250 Report post Posted February 20, 2016 probably have some from e28 or e24 etc . 021433600 [email protected] Will be in contact, thanks. Quote Share this post Link to post Share on other sites
