WYZEUP
FS: E36 Med case diff 3.07
As per tittle i have just acquired a E36 medium case 3.07 open diff..... i was going to transfer the internals into a e30 med case diff to get the ratio i was after but came across a low ratio e28 diff and rear cover so now have a spare diff that is of no use to me now....
$250
Edited by WYZEUP
Hi pal.
Have you got both the e36 e30 diff covers there??
I have a mid case going in my e21. Interweb says use a e30 cover, do you mind taking some measurements for me ??
I have got a med case e30 cover but not for sale. I can possibly measure if you need
Thanks .I just want to know if the mounting points are in the same place. IE distance from the mounting face to the front of the diff mount .
Thanks .
I have seen that e30 guys swap e36 covers in. Just wanting to check before I buy a cover.
Bump.
Also have a e36 pedal box with clutch master cylinder and all springs etc... $150
