boy benz
WTB Standard E39 Wheels & Tyres
In need of a full set of wheels & tyres to fit a BMW E39 Sedan
Preferably in Auckland. Standards nothing to flash or expensive
What size?
I have some 16's with good tyres from an e46
Alex: PM'd you
Nathan: E39 has a bigger centre bore of 74.1mm instead of the standard 72.6mm so E46 wheels wont fit.
Not a straight swap I believe the e39 has an odd hub dia of 74.1mm while the e46 has 72.56mm if correct you will need hub spacer. Also check the wheel off set as the 5ers seem to be a low off set while the 3s are higher. Google it their will be heaps of info on it
