WYZEUP 283 Report post Posted April 11, 2016 So im working my way through the mock up stage of my M60 swap into my e30 and have come to a hurdle on the power steering side of things as none of the factory lines will fit/work without manipulating the lines and im not comfortable with heating and bending the steel line that have already been bent. Has anyone else used stainless braided hose before or had custom hoses made, understanding the car is on jack stands so i dont think the enzed would be too pleased about getting in and out with it on stands. Any help would be great. cheerz Quote Share this post Link to post Share on other sites
Michael. 2313 Report post Posted April 11, 2016 Just need to measure the length you need really, fitting to fitting. I had a swivel end fitted to a hose I had made up for my E36 1UZ swap. Worked well. Only really need to do the high pressure side with proper fittings, cost about 150 from memory. Quote Share this post Link to post Share on other sites
M3AN 4111 Report post Posted April 11, 2016 Yes, I just took the measurements and specs to Enzed and they made them for me, fitting was a breeze. I got them about an inch longer than I needed just to be sure. Quote Share this post Link to post Share on other sites
