moolahlee 1 Report post Posted April 21, 2016 Hi there, Recently purchased a E38 728i and have known there was a lingering problem of some oil leaking around the lower left hand side of the engine. It often results in burnt oil smoke coming from the bonnet while idling in traffic. It has also increased gas consumption and a loss of low end torque. Have googled the symptoms but want to hear some thoughts from you guys. The car has done 186xxx and is good mechanical condition otherewise. Thanks heaps 1 Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted April 21, 2016 Rocker cover , oil filter remote housing, dip stick breather hose, sump gasket, oil filler cap, PCV valve & associated breather hoses 1 Quote Share this post Link to post Share on other sites
NZ00Z3 190 Report post Posted April 21, 2016 Symptoms are hallmark of a crank case ventilation problem Quote Share this post Link to post Share on other sites
Allanw 1081 Report post Posted April 21, 2016 Rocker cover , oil filter remote housing, dip stick breather hose, sump gasket, oil filler cap, PCV valve & associated breather hoses And you mean ALL of them, not one of them, right? Quote Share this post Link to post Share on other sites
NZ00Z3 190 Report post Posted April 21, 2016 Sounds like you have a pressurised crank case forcing oil out some where. Suggest: 1) Find the leak and order the gasket 2) Order the PCV and all associated hoses. 3) Change the PCV and all Associated hoses 4) change the leaking gasket. Quote Share this post Link to post Share on other sites
