Scrambler
E32 Brake Booster
vaccum or hydro?
Probably both I'm thinking, its for an m5X e30 swap. Have to work out how its going to go. Didn't want to have to drill new holes in the fire wall
a second hand part is 30 years old now.
try new from BNT or import
Clio 2001+? Has anyone had any experience with these? Will the brakes still feel normal(ish) and have enough vac to stop? good point btw
You do get a slightly harder pedal feel with the smaller boosters. Pretty sure E32 dual booster fits with the right rear plate and you wouldn't lose as much brake assist.
jibs05 on here has one in his swapped e30, or the other option is an e21 booster which luckily brent is currently wrecking atm
On the hunt for a Clio booster now. Got on the phone with some knowledgeable chap from Christchurch who told me about the hydro brake set up which runs off the power steering. I had no idea. Rebuilt or new OEM e32 booster would prbably cost an arm and a leg if I could find it so I'll go for a clio booster. Cheers
