M M 250 Report post Posted May 3, 2016 I'm after a single mass M30 flywheel to fit my M30B35. Could make use of a clutch too if someone happens to have one as I'm looking at getting one rebuilt to stronger specs. Can anyone confirm if M30B28 flywheels are the same? I'm in Auckland but beggars can't be choosers and all that. Quote Share this post Link to post Share on other sites
BM WORLD 1291 Report post Posted May 3, 2016 m30b28 will work same as m30b25 m30b30 m88 , can even use a M10 or s14 one at a push with a rebuilt stronger clutch setup Quote Share this post Link to post Share on other sites
M M 250 Report post Posted May 3, 2016 m30b28 will work same as m30b25 m30b30 m88 , can even use a M10 or s14 one at a push with a rebuilt stronger clutch setup Cool, thanks. I would rather go with the larger clutch so that when I boost the motor later on it can handle it ok. I seem to have found an M30 one. Quote Share this post Link to post Share on other sites
Ace Of Spades 51 Report post Posted May 3, 2016 I'm after a single mass M30 flywheel to fit my M30B35. Could make use of a clutch too if someone happens to have one as I'm looking at getting one rebuilt to stronger specs. Can anyone confirm if M30B28 flywheels are the same? I'm in Auckland but beggars can't be choosers and all that. Have one in east auckland, standard one Quote Share this post Link to post Share on other sites
M M 250 Report post Posted May 3, 2016 Have one in east auckland, standard one Ok thanks. If this other one doesn't work out I will be in contact. Quote Share this post Link to post Share on other sites
M M 250 Report post Posted May 10, 2016 Still looking. I've sorted the clutch kit but I really need the flywheel now. Quote Share this post Link to post Share on other sites
