M M
WTB: M30 Single Mass Flywheel
I'm after a single mass M30 flywheel to fit my M30B35. Could make use of a clutch too if someone happens to have one as I'm looking at getting one rebuilt to stronger specs.
Can anyone confirm if M30B28 flywheels are the same?
I'm in Auckland but beggars can't be choosers and all that.
m30b28 will work same as m30b25 m30b30 m88 , can even use a M10 or s14 one at a push with a rebuilt stronger clutch setup
Cool, thanks. I would rather go with the larger clutch so that when I boost the motor later on it can handle it ok. I seem to have found an M30 one.
Have one in east auckland, standard one
Ok thanks. If this other one doesn't work out I will be in contact.
Still looking. I've sorted the clutch kit but I really need the flywheel now.
