325_driver
fly wheel
hey guys
fly wheel bolts ?
torque specs ?
what are the numbers
im searching on the web and cant find alot
cheers
I done my one a coupala weeks ago and I replaced the nuts and I was told 120N on each bolt (my one has 8)
I dont know but I dont think the bolts need replacing coz theyr prety hight tensile 12.?
You should also check your flywheel bolts
Ring Team Mc Millian theyl tell you for sure.
Dont ring Jerry Clayton though... they suck big balls
I made an alignment tool for the friction plate on the lathe
you should do the same otherwise you will never put the gearbox back in
Team Mc Millan for sure
ill give em a ring once i go for a snooze
cheers guys
whats this so called difficulty im going to have with getting the gear box back on ?
If you tighten your pressure plate without the hole of the friction plate being EXACTLY in the midle and in line with the pilot bearing, the input shaft of the gearbox will never go in
and youl be stuck under the car wigling the gearbox around for days and it wont go on.
thats why you need an alingment tool to get it exactly center. it should be an exact replica of the output shaft.
just buy a clutch aligning tool from repco or BNT, you need it so your clutch assembly is centered when you put it back together.
There's some pics on this in the g/box converserion thred in the maintenance section. The BNT clutch alignment tool will suffice.
