Mad_Max 235 Report post Posted July 6, 2016 So I'm having a few problems installing EasyDIS v44 on a virtual machine, hoping someone can tell me what I'm doing wrong? I can get the virtual machine set up and configured correctly (there's a few differences between the guide and the version of VM I'm using), and have been able to set up INPA, EDIABAS etc, and that's all working correctly. Following the guide found at http://www.bimmerforums.com/forum/showthread.php?1297683-How-to-install-DIS-w-EasyDIS-v44-step-by-step, I set up a new VM with the same settings, but for the life of me I cannot get it to install EasyDIS. Anyone have any pointers? I'm positive it's something I'm doing wrong but for the life of me cannot work it out Quote Share this post Link to post Share on other sites
Haitoman 110 Report post Posted July 6, 2016 1. What version of ediabas have you got installed? 2. Make sure you set the disk size to exactly 18.635GB. 3. Make sure you set up the three network interfaces as per the instructions. 4. Also you need to do this: Choose "Touchscreen Calibration" in the Administration menu of the DIS. Choose option 1, Config EDIABAS Choose option 3, and set up FISTER as the interface Start a terminal / shell by hitting "CTRL + ALT + F4" (F1, F3 and F4 are shells, F2 is the DIS GUI). Login as "root" with the password "12345". Choose to change the password when prompted to do so. Remember the new password! Make a note of it. Edit /etc/initab and comment out the line starting with "vm". You can do this from the DIS and FISTER-menu as well if you dont feel comfortable using "vi". Start ifhserv32.exe (I also start head emulator) If you hover over ifhserv32 on the task bar it should show an ip number when you start up VMware and the DIS connects. Quote Share this post Link to post Share on other sites
tawa 150 Report post Posted July 6, 2016 I did this a while back, give us more detail on exactly what your problem is and it might jog my memory. Quote Share this post Link to post Share on other sites
Mad_Max 235 Report post Posted July 6, 2016 1. What version of ediabas have you got installed? 2. Make sure you set the disk size to exactly 18.635GB. 3. Make sure you set up the three network interfaces as per the instructions. 4. Also you need to do this: Choose "Touchscreen Calibration" in the Administration menu of the DIS. Choose option 1, Config EDIABAS Choose option 3, and set up FISTER as the interface Start a terminal / shell by hitting "CTRL + ALT + F4" (F1, F3 and F4 are shells, F2 is the DIS GUI). Login as "root" with the password "12345". Choose to change the password when prompted to do so. Remember the new password! Make a note of it. Edit /etc/initab and comment out the line starting with "vm". You can do this from the DIS and FISTER-menu as well if you dont feel comfortable using "vi". Start ifhserv32.exe (I also start head emulator) If you hover over ifhserv32 on the task bar it should show an ip number when you start up VMware and the DIS connects. 1. I'm not sure to be honest, I think it's 6.4.7? If you know how to check, let me know and I'll tell you the exact version. EDIABAS, INPA and NCS Expert all work fine, both on a virtual XP machine and my Win10 64 bit. 2. Yes, I did read that part was critical and ensured it was done. 3. Have followed the instructions given in the link above to the letter, and it doesn't seem to find the *.iso file to load the OS, hence why I'm sure it's something I'm doing wrong. 4. I haven't gotten anywhere near any of this part yet to be honest, it's the first I've seen of that needing done so will keep it in mind, thanks for the tips! I did this a while back, give us more detail on exactly what your problem is and it might jog my memory. Basically I just can't seem to get the virtual machine to load the OS off an .iso file, no matter what I try, convinced it's a setting I've missed or something I'm doing wrong - or could be the copy of EasyDIS I got is no good. Quote Share this post Link to post Share on other sites
tawa 150 Report post Posted July 6, 2016 Yeh sounds like virtual box might not be getting the CD image passed to it correctly or something; the bios is showing a CD drive right? Quote Share this post Link to post Share on other sites
Mad_Max 235 Report post Posted July 6, 2016 Yes, I can get a virtual drive set up and assign a letter to it, then change the settings in VMware Workstation 12 to tell it to load the ISO from that drive letter, and change the BIOS settings inside the VM to tell it to load from the virtual drive, but it just doesn't do it. It keeps defaulting to a network boot. Occasionally it has looked like it wanted to try but gives up saying it can't load the operating system...... starting to think it's a corrupt copy of EasyDIS, might have to start searching for another version me thinks Quote Share this post Link to post Share on other sites
Haitoman 110 Report post Posted July 6, 2016 Ah...hang on. There are two versions of DIS kicking around. One is a full installer the other (easyDIS) is already a preconfigured vmdk. I'll put full step by step instructions up this weekend if you still haven't got it sorted out. Quote Share this post Link to post Share on other sites
Mad_Max 235 Report post Posted July 6, 2016 Ah...hang on. There are two versions of DIS kicking around. One is a full installer the other (easyDIS) is already a preconfigured vmdk. I'll put full step by step instructions up this weekend if you still haven't got it sorted out. You're a legend, thanks heaps, really do appreciate that. I think mine is an installer version, in the process of downloading another version as well so will have a look at them both and try everything. Quote Share this post Link to post Share on other sites
tawa 150 Report post Posted July 6, 2016 Here's a file listing of the version I've got if it helps, on dropbox somewhere and can probably find the link if you want it... Quote Share this post Link to post Share on other sites
Mad_Max 235 Report post Posted July 6, 2016 Here's a file listing of the version I've got if it helps, on dropbox somewhere and can probably find the link if you want it... Fantastic, thanks, I'd say at a guess I got an incomplete version, as my file list looked nothing like that at all. So that may be the problem after all. If you've got the link that would be fantastic, I also have the Siemens MS41 flash tool now if you want a copy of that? Quote Share this post Link to post Share on other sites
tawa 150 Report post Posted July 6, 2016 Fantastic, thanks, I'd say at a guess I got an incomplete version, as my file list looked nothing like that at all. So that may be the problem after all. If you've got the link that would be fantastic, I also have the Siemens MS41 flash tool now if you want a copy of that? Sounds like a plan, PM me your email address you use for dropbox and I'll add you in, you should be able to upload the flash tool to there as well. Quote Share this post Link to post Share on other sites
Haitoman 110 Report post Posted July 7, 2016 Make sure you get the English version. If you see DE anywhere...run away. Quote Share this post Link to post Share on other sites
Haitoman 110 Report post Posted July 7, 2016 GT1/DIS44 requires ediabas 6.4.3 Some of this might help too: After you have created a shortcut to IFHSrv32 on your desktop, close all the open pages in Windows and return to your newly-created DIS “virtual machine”. There is more work to do inside DIS in order to ensure that not only can it see our diagnostic head, but that the head can also talk to DIS. If you are having difficulty seeing the entire DIS screen, left click somewhere inside the DIS window, then hold down the CTRL + ALT keys whilst you press the ENTER key. This should resize the DIS window so that you can see the Administration button on the lower right hand side of the screen without having to scroll down. If the mouse pointer inside the DIS window becomes a bit temperamental, it can easily be rectified at any time by holding down the CTRL + ALT keys to bring up the windows mouse pointer. Just superimpose the windows mouse pointer over the DIS mouse pointer and left click and the functionality of the mouse pointer in DIS will be restored. Push the Administration button in DIS and from the DIS menu choose The Calibrating touch screen button (second from the bottom). Enter the 5 digit dealer number password you chose during installation (the recommended password was 12345) and wait for the utilities menu to pop up. When it does, choose Option 7 (SCOADMIN NETWORK). A window will pop up showing 2 green driver icons – at the top of the screen will be the SCO TCP/IP Loopback driver – DO NOT TOUCH THIS DRIVER. Below this you will see a second driver – AMD PCNet-PC1 Adapter Compatible – PC1 Bus#0, Device #17, Function #0. The configuration settings assigned to this device may not work with your particular machine so left click on the AMD PCNET – PC1 Adapter Compatible line to highlight it, then from the Hardware Menu at the top of the screen, choose “Remove network device”. The next step is to re-add an AMD PCNet-PC1 Adapter Compatible that your machine will recognise by again going to the Hardware menu and choosing Add new LAN adapter. A window will pop up showing AMD PCNet-PC1 Adapter Compatible devices found on your computer – this is an important step as in my case, the original adapter was set to work off Bus #0, Device #17, Function #0 whereas my computer requires the adapter to work off Bus #2. Choose the first AMD PCNet-PC1 Adapter Compatible on the list then yes to add the new adapter and a pop up will ask what protocol you want to add to the adapter – choose SCO TCP/IP from the options displayed and a settings panel will pop up. The first line “Local Host Name” should already be populated with gt1ap. The next line is where we need to enter the IP Address, which is 192.168.68.30 . When you tab to the next line, the Netmask address (255.255.255.0) should back populate, as should the Broadcast Address 192.168.68.255, TCP connections and Pseudo ttys lines. Hit OK to accept these adapter settings and return to the SCOADMIN NETWORK page where you will see your newly created adapter listed in place of the one you deleted. Before going further, hold down CTRL + ALT and hit ENTER to pop up the toolbar of your Virtual Machine and press the CTRL + ALT keys together to pop up the Windows mouse pointer. From the Virtual Machine Edit menu, choose Virtual Network Settings, then on the Next Screen, Select the Host Virtual Network Mapping Tab. Now Click on the > symbol located on the Right hand side of the VMware Network Adapter VMnet1 line and choose Subnet... to view its IP Address and Subnet Mask. Ensure that the IP Address is listed as 192.168.68.0 by altering it if necessary and that the Subnet Mask is 255.255.255.0. When this has been completed, click OK and then click the Apply button at the bottom of the screen before choosing OK to exit the editor and save your settings. After the editor has closed, left click back inside the SCOADMIN NETWORK window and this time choose Exit from the Hardware menu. A message will pop up telling you that your settings have changed and asking if you want to relink the kernel. Choose yes and a black screen will pop up, advising you that the kernel is to be rebuilt, relinked and asking if you want to use it to rebuild the system. Choose yes to all of the prompts. The Virtual machine will reconfigure itself to adapt to your new settings, then shut itself down and restart. When DIS appears, again choose the Administration button, then Calibrating touch screen. Enter the 12345 password and again choose Option 7. SCOADMIN NETWORK. We need to view our EDIABAS.ini and hosts settings from the Unix side, to ensure we can talk to our Windows software and interface. When the SCOADMIN NETWORK screen appears, left click in a blank section of the window and hit CTRL + SysRq to access the Unix root file (remember the black screen you encountered when the kernel was rebuilding?) at the login prompt, type root, then choose option 1 to choose a password. The easiest password to remember if you get stuck is password so type password once then again when prompted to confirm your choice. A few lines of text will be generated by the root file, the last being TERM = (scoansi) _ hit ENTER when you see this line and # should appear at the beginning of the next line. Be careful when working with UNIX, as commands are case sensitive . After the # type cd /etc another # will appear at the beginning of the next line – after it, type vi ediabas.ini. You should view this file to ensure that the correct IP address 192.168.68.1 and port 6801 are identified. If not, use the UNIX command summary to edit and resave the file. After viewing the correct EDIABAS.ini file, type :q! to exit without changes or :wq to save changes and exit the file. When the # prompt reappears, type vi hosts. A file will appear listing IP addresses, it will look something like this:- # @(#) hosts, v 6.1 1993/08/21 02:17:48 stevea Exp – STREAMware TCP/IP source e # SCCS IDENTIFICATION 127.0.0.1 localhost 192.168.68.30 gt1ap gt1ap 192.168.68.32 gt1ap2 gt1ap2 “hosts” x lines xxx characters We need to modify this file so that it can find our diaghead, so use the down arrow to place the cursor on the line 127.0.0.1 localhost then type o (to open a new line underneath the present line). Type 192.168.68.1 diaghead diaghead then hit the ESC key Note that keystrokes are the IP address(TAB)diaghead(SPACE)diaghead(ESC) The modified files should now look like this:- # @(#) hosts, v 6.1 1993/08/21 02:17:48 stevea Exp – STREAMware TCP/IP source e # SCCS IDENTIFICATION 127.0.0.1 localhost 192.168.68.1 diaghead diaghead 192.168.68.30 gt1ap gt1ap 192.168.68.32 gt1ap2 gt1ap2 “hosts” x lines xxx characters After hitting the ESC key type :wq to exit the file and save your changes and return to the # prompt. At the # prompt, type init 6 to reboot the program or init 0 to shutdown DIS. NEARLY FINISHED! DIS should always be shut down by choosing the Administration button, then going to the utilities menu from the calibrating touch screen button and choosing Option 0 In order to use DIS to diagnose your car, first hit the IFHSrv32 shortcut you created earlier so that the Network between DIS and EDIABAS is supported. The IFHSrv32 icon will appear on your toolbar. Make sure that there are no Antivirus programs or firewalls running, then start your DIS/GT1 Virtual Machine. A few minor adjustments may need to be made, depending upon what diagnostic head you are using – for example I use an ADS interface, so I had to use the Utilities menu to change the translator to “FISTER” and ensure that vm was switched off as INPA had been set up to use ADS rather than an OBD interface. Remember that if you do make changes, you will also need to restart EDIABAS from the Utilities menu to ensure that your settings are adopted and saved. Quote Share this post Link to post Share on other sites
Mad_Max 235 Report post Posted July 7, 2016 Sounds like a plan, PM me your email address you use for dropbox and I'll add you in, you should be able to upload the flash tool to there as well. Pm sent. Make sure you get the English version. If you see DE anywhere...run away. Thanks, will keep that in mind. And will have a good read at the rest of the tech stuff as well when I get to setting it up, much appreciated. Quote Share this post Link to post Share on other sites
polley 916 Report post Posted July 7, 2016 Sounds like a plan, PM me your email address you use for dropbox and I'll add you in, you should be able to upload the flash tool to there as well. I assume you're pirating a version of ms41 flash tool.... It's cheap, why bother? If people keep doing this the developer won't bother developing other cool software and just keep it to him self. Quote Share this post Link to post Share on other sites
Mad_Max 235 Report post Posted July 7, 2016 I assume you're pirating a version of ms41 flash tool.... It's cheap, why bother? If people keep doing this the developer won't bother developing other cool software and just keep it to him self. I hear your point there, however your assumption is incorrect - AFAIK it's not a pirated version, this is a shareware/freeware version. I can't afford to run the risk of having pirated software on my work computer. And having developed things in the past, I do know the frustration of developing stuff only to get nothing for it. Fully agree with your points about it being cheap and about the developer, there is no argument there. And most freeware versions you can make a donation to the developer. Quote Share this post Link to post Share on other sites
tawa 150 Report post Posted July 7, 2016 I assume you're pirating a version of ms41 flash tool.... It's cheap, why bother? If people keep doing this the developer won't bother developing other cool software and just keep it to him self. I was assuming it was the same situation as INPA and easydis etc, took a number of goes to find a workable version of that... Quote Share this post Link to post Share on other sites
polley 916 Report post Posted July 7, 2016 I don't know of a free version of ms41 flash tool, it's a aftermarket thing developed by someone else, they do a ews delete tool as well as other things. My apologies if we are talking about different software. 1 Quote Share this post Link to post Share on other sites
Mad_Max 235 Report post Posted July 7, 2016 It may not be the exact same tool by the same developer, however I and I'm sure John as well fully understand where you were coming from, and that's cool - no offence taken, no butt hurt received lol. Quote Share this post Link to post Share on other sites
Mad_Max 235 Report post Posted July 8, 2016 Massive thanks to both John and Andrew. Turns out I must've had a bad copy, as I got another .ISO file last night, opened VM Machine, pointed the operating system to the new ISO file and.... lo and behold, EasyDIS installed..... then GT1............ So next step (sometime over the weekend lol) will be to work through all the advice here on the settings, then I can test it out. Again, thanks to both for your input and help, it's very much appreciated! 1 Quote Share this post Link to post Share on other sites
M3_Power 636 Report post Posted July 16, 2016 There's so much error in that install instruction above .... Where do I start?!!! Hmmmm First off you don't need three network drivers just the one. Having three actually messes things up. Second easydis has a built in diagnostic head emulator so you don't need to run one separately but you can if you like. Third, you don't need to input 192.168.68.1 diaghead diaghead - that also confuses the system. Quote Share this post Link to post Share on other sites
Mad_Max 235 Report post Posted July 16, 2016 There's so much error in that install instruction above .... Where do I start?!!! Hmmmm First off you don't need three network drivers just the one. Having three actually messes things up. Second easydis has a built in diagnostic head emulator so you don't need to run one separately but you can if you like. Third, you don't need to input 192.168.68.1 diaghead diaghead - that also confuses the system. Interesting...... thanks for the input Tom, I haven't gotten as far as even trying to configure or connect it yet, got sidetracked with a few other things that popped up but will keep this in mind. Quote Share this post Link to post Share on other sites
Haitoman 110 Report post Posted July 16, 2016 I'm sure there are a whole heap of installation instructions floating around, but it was that one that worked for me. Quote Share this post Link to post Share on other sites
Eddie SLMT 0 Report post Posted February 29, 2020 (edited) On 7/6/2016 at 11:08 PM, Mad_Max said: Fantastic, thanks, I'd say at a guess I got an incomplete version, as my file list looked nothing like that at all. So that may be the problem after all. If you've got the link that would be fantastic, I also have the Siemens MS41 flash tool now if you want a copy of that? Hi,I'm really looking for the MS410 flasher,want access to Immo delete On e39. Edited February 29, 2020 by Eddie SLMT Model was not specified Quote Share this post Link to post Share on other sites
