Hellrot 325Ti
Getrag Manual Conversion **Cheap**
E36 Getrag 220 Manual Conversion
$550ono
Located - Napier, Hawke's Bay
Willing to ship at your expense
Included:
Getrag 220 Gearbox (230,000Kms)
Pedal Assembly
Short Shifter
Shifter linkages
Shifter Boot
Driveshaft
Clutch Master/Slave Cylinders
Crossmember
No clutch/flywheel or hydraulic lines sorry, although I'd recommend a lightened flywheel anyway.
Sadly these aren't the pics of another conversion I owned, this one comes with the exact same gear though :)
Please note: As this is a very cheap package, I won't do holds for anyone. I am headed from Napier to Tauranga
next Wednesday/Thursday and am happy to drop off to anywhere in between :D
post-53445-0-30825500-1468416226_thumb.j
post-53445-0-79391300-1468416230_thumb.j
post-53445-0-85737000-1468416234_thumb.j
post-53445-0-34160000-1468416238_thumb.j
Edited by RichardLongley001
On 8/1/2016 at 11:21 PM, Bikeage said:
Is this sold?
If it has, I might be able to get you one, will have the hydraulic lines etc. Only thing you'd need to source would be a new clutch as this one is quite worn. If it's to go in an E30 I can get the pedal box as well. Guy wants $600 for it all up plus shipping ex Invercargill.
