BMRBOI 8 Report post Posted November 21, 2016 Hi team Any information on these? I picked up a 12/1990 e36 325i manual (didn't know they made them that early) thinking it would be the getrag 250 but it is a zf. Are they stronger/same as the 250 getrag? Cheers, Niroy Quote Share this post Link to post Share on other sites
M3AN 4147 Report post Posted November 21, 2016 I asked that question the other week and was told in the case of the 5 speed the ZF is stronger and more desirable. Quote Share this post Link to post Share on other sites
BreakMyWindow 1971 Report post Posted November 21, 2016 Put the last 7 digits of your vin in to an online bmw parts catalog and you can check which zf box you have. Car is definitely a factory manual? Or could've had the zf box and associated running gear for it installed. Quote Share this post Link to post Share on other sites
BMRBOI 8 Report post Posted November 21, 2016 Factory manual according to the VIN. Attached is the gearbox option on realoem. ZF factory fitted. I seem to recall the 328i manual box looking bigger than this one however. I wonder why the early e36 had this box? Might have borrowed it from an E34 manual as they started producing them earlier? Quote Share this post Link to post Share on other sites
zero 1162 Report post Posted November 21, 2016 zf box is much better than the getrag. You did well. Quote Share this post Link to post Share on other sites
