curryinahurry 39 Report post Posted December 5, 2016 Hello, I'm looking for a front left shock absorber for my FL 325i. Let me know if you have anything in Auckland. Cheers, Andrew Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted December 5, 2016 (edited) The shocks are inserts and not handed... only the struts are handed. I would also suggest changing both fronts if only one is faulty. There are also 2 sizes 45mm & 51mm. Most 325ms had 51mm Edited December 5, 2016 by *Glenn* 2 Quote Share this post Link to post Share on other sites
gjm 3299 Report post Posted December 5, 2016 25 minutes ago, *Glenn* said: I would also suggest changing both fronts if only one is faulty. There are also 2 sizes 45mm & 51mm. Most 325ms had 51mm This. Definitely. Not replacing both is at best a false economy; in the worst case it could be dangerous. Quote Share this post Link to post Share on other sites
curryinahurry 39 Report post Posted December 6, 2016 Thanks for the pointers guys! The one I'm replacing had already been replaced by the last owner (evident by the markings present on the strut). It's hard to tell what I'm getting when I'm buying second hand. Does anyone refurbish these or have good aftermarket ones with factory performance.? On 05/12/2016 at 1:38 PM, *Glenn* said: The shocks are inserts and not handed... only the struts are handed. I would also suggest changing both fronts if only one is faulty. There are also 2 sizes 45mm & 51mm. Most 325ms had 51mm Quote Share this post Link to post Share on other sites
