Karter16 487 Report post Posted June 22 3 hours ago, deedub said: Thank you. I'm a complete noob when it comes to vehicle ECU's. I've been trying to track down info around the motronic 1.x versions. Still got a bit of searching/reading to do but thanks for the heads up on the processor used.ย I don't have a read of the program ROM yet. Still trying to figure out how I connect to it so I can get it off. I use Linux for everything except gaming. I'm hoping support for tooling on Linux is reasonable. Keep seeing windows come up in convos around diagnostics... TunerPro have a bunch of xdf's (definition files for tunes) for the Motronics as well as binary reads of the tunes - might be worth poking in to:ย https://www.tunerpro.net/downloadBinDefs.htm#BMW 1 Quote Share this post Link to post Share on other sites
Karter16 487 Report post Posted June 24 Couple of updates: 1: The wheels arrived today ๐ Mandatory photo, although we all already know what ARC8's look like ๐ 2: The male MAF sensor connectors arrived. I don't actually have need of these for myself, but I finally came across them and thought I'd order some to confirm they're a match and if so share the details with everyone as saves having to pay Turner money for their relocation harnesses. These things appear to be the exact same item Turner are using and they come with the pins and seals. I ordered 5 of these for the princely sum of $9.58USD total including shipping. per-unit price is $1.24USD. You can purchase your own (you can order singles) here:ย https://www.hdconnectorstore.com/productdetail/32496.htmlย ย 4 Quote Share this post Link to post Share on other sites
Karter16 487 Report post Posted June 25 I ordered tires this evening. After much research I decided to go with the Bridgestone Potenza Sport. I had been planning to take the well-trod route of Michelin PS4S's, however they're not available in New Zealand (and importing tires was just going to be too expensive to make sense) in any of the sizes remotely close to what I need (I confirmed this with Michelin NZ directly), this was a surprise especially given I'd checked on their NZ website that those sizes were available hereย ๐ This meant I then needed to figure out alternative options. In Michelins that meant PSS's or PS5's (no Cup options available in NZ in the sizes I need). The PSS's are too old, and the PS5's while by all accounts very good had me a bit concerned about the softer tire wall than the PS4S. The RE050A's that I'm running currently, are fairly stiff in the sidewall department and while objectively terrible compared to modern options I am used to the stiffer sidewall. By moving to 18's I'm already introducing more compliance for a better ride and road stickability (that's the technical term ๐), and I was a little concerned about also moving to an even softer sidewall as well. I then looked wider, and after a bunch of research, looking at what is available in NZ, settled on the Potenza Sport. The Potenza Race would be an even better option I think, but they're not available in 18in options. The RE71-RS's while the stickiness would have been giggle-worthy, don't give the same degree of feedback and would be impractical in wet conditions, so the Sport it is. TireReviews.com have a good review of it and on dry handling it's very close to the PS4S, slightly better in the wet, and ranks worse on comfort (due to the firmer sidewall), slightly worse on noise and worse on wear. The wear doesn't bother me as I won't do enough km's anyway, the firmer sidewall I'm okay with and the noise will still be a lot better than the RE050A's anyway. This is all splitting hairs of course, but might as well get the best option I can. Big shout out to @Palazzo for suggesting Costco. Bridgestone NZ direct have the best price out of the rest due to a special deal currently which comes to only $2376.32 NZD for all 4 tires fitted. Costco, for exactly the same thing, is $1379.94, plus in addition you get a $360 store credit as well. Given we regularly shop at Costco for essentials this means the end cost for the tires comes to $1020. Which is quite astonishing to me. That's significantly less than I paid for new performance tires for my 318i in 2007! 3 1 Quote Share this post Link to post Share on other sites
Eagle 1778 Report post Posted June 25 1 hour ago, Karter16 said: Bridgestone Potenza Sport. I recently looked at those for my S55 as they were the only good in my sizes along with theย PS5's (both aroundย $1900 trade). Uponย reading reviews they didnt have the characteristics i was after for the car so i went with theย PS5's. That pricing is insane in this day and age though, buying power that good orย tyre shops got big markup, maybe both. Would of been interesting to see what the PS5 cost in theย same sizing.ย May have to drive to Auckland for future tires. 1 Quote Share this post Link to post Share on other sites
Karter16 487 Report post Posted June 25 11 minutes ago, Eagle said: I recently looked at those for my S55 as they were the only good in my sizes along with theย PS5's (both aroundย $1900 trade). Uponย reading reviews they didnt have the characteristics i was after for the car so i went with theย PS5's. That pricing is insane in this day and age though, buying power that good orย tyre shops got big markup, maybe both. Would have been interesting to see what the PS5 cost in theย same sizing.ย May have to drive to Auckland for future tires. PS5โs came to $1775.94. The fronts (245/40R18) were cheaper than the Potenza Sports, but the rears (255/40R18) were significantly more for whatever reason. 1 Quote Share this post Link to post Share on other sites
Palazzo 533 Report post Posted June 25 10 hours ago, Eagle said: I recently looked at those for my S55 as they were the only good in my sizes along with theย PS5's (both aroundย $1900 trade). Uponย reading reviews they didnt have the characteristics i was after for the car so i went with theย PS5's. That pricing is insane in this day and age though, buying power that good orย tyre shops got big markup, maybe both. Would have been interesting to see what the PS5 cost in theย same sizing.ย May have to drive to Auckland for future tires. Friends got tyres direct from importer last year. A set of 4 was about 20% more than 1 from a (cheap) retailer. So somewhere between the importers margin and the retailers margin is a healthy number. 1 Quote Share this post Link to post Share on other sites
Eagle 1778 Report post Posted June 25 (edited) 11 hours ago, Karter16 said: PS5โs came to $1775.94. The fronts (245/40R18) were cheaper than the Potenza Sports, but the rears (255/40R18) were significantly more for whatever reason. Yeah pricing can be odd. I run 245/45R18 fronts cost about the same.ย PS5's retail fitted\balancedย inย 275/40R18ย were $820 vs $589 for Potenza's. Trade on the PS5's was $570 by itself.ย 59 minutes ago, Palazzo said: Friends got tyres direct from importer last year. A set of 4 was about 20% more than 1 from a (cheap) retailer. So somewhere between the importers margin and the retailers margin is a healthy number. Importer is probably the one making most of the money. Currentย advantage tyre retail Michelinย pricing is aย 20-30% markup on trade priceย all things being equal.ย I find aย good special\sale seems bring the retail price to around the trade price lots of consumable items. The saving in trade is being about to fit them yourself and save $200 on a set, most places seem to chargeย $~50 per tyre for fitting and balancing. Edited June 25 by Eagle Quote Share this post Link to post Share on other sites
Karter16 487 Report post Posted June 29 Yesterday I got the tires fitted to the ARC-8's and today I put them on the car and went for a test drive. It will surprise no one that this setup is a huge improvement over 19s with old RE050A's. The first few minutes of driving were weird, it felt like I'd lost a bunch of road sensation and it took a few minutes to realize it was just harshness and unhelpful noise that was missing. All the useful feel of the car and the road through the seat and wheel was still there, it was just a quieter smoother ride with much less of the unnecessary hum, buzz, fizz, whatever you want to call it. As soon as I realised I could still read the road as before I settled in and started comparing the difference. I can't talk to how the Potenza Sports compare to the PS4Ss, but compared to old RE050A's they are very significantly quieter, I first noticed this by noticing that the CSL intake sounded louder! 18inch wheels are clearly what this car was designed for and are better than 19s in every way when it comes to ride quality and feel. I'm very happy I opted for the firmer sidewall of the Potenza's over the, softer than PS4S, PS5's. The accuracy and immediacy of handling is still there, significantly improved upon with new sticky tires. I need to give a big shout out toย Bry5onย for his advice to put 9in wheels up front with the ET42 offset. I'd always been worried about putting anything too wide up front, afraid of ending up with heavy, dull steering, but with pretty much the correct offset and lighter wheels and tires all the precision and immediacy is still there, and when you get on to windy open road the feel of the car with a larger tread patch up front and closer to square setup overall is just superb.ย On the topic of weight. The combination of lighter wheels and lighter tires means I'm almost 4kg lighter per corner, which (including weight of the rotors) is close to a 14% reduction in rotating mass, and I can really notice the difference. I'm always skeptical of my butt-dyno because I'm always concerned it is excessively influenced by the "wallet factor". But in this case there is no doubt. Acceleration and braking both noticeably benefit, not to mention how much better the car ride and holds to the road with less unsprung mass. In summary, as you would expect, this is a fantastic upgrade in every way. I do want to thank everyone who took their time to give me advice and suggestions on this project. It wasn't one I was planning to do right now, and as a result I had not performed my usual excessive amount of research and preparation well in advance. I'm very grateful to everyone who shared their knowledge and experience to help me arrive at the ideal outcome. Thank you! Likeย heinzboehmerย I've very much missed driving the car while it's been laid up, so like him when I got it back on the road a short test drive turned into a longer one. Only I ended up at a slightly less globally-famous landmark. The Mt Rex sand processing facility in Helensvilleย ๐ Also, it's winter here, it was raining, and the sun was in the wrong place. 7 Quote Share this post Link to post Share on other sites
Karter16 487 Report post Posted July 19 (edited) Time for a few little updates: First the wheels/tires - having had some more time driving on them, and in particular on some dry roads I can't believe how much quieter the Potenza Sports are than the RE050As. I know that one of the complaints about the Sport is that it's noiser than the PS4S, but honestly it's still a huge improvement over what I had before, so still feels like a win to me. I'm super super, happy with the 18x9/18x9.5 combo, and the lightweight 18in rims have given me everything I was hoping for in terms of ride + driving feel. I try very hard to make sure that each change I make to the car aligns to my goal of "improving the driving experience", and this change has absolutely nailed that brief. As an aside, at the time that I installed the RACP brace I also replaced the rear cover on the diff with a new one with new bushes. I'm super happy to report that the combination of these two things has completely addressed what remained of the diff slop/M-Clunk/whatever you want to call it. I'm stokedย about this as wasn't sure whether the diff was getting a bit worn out, but I'm super happy with how this has resolved, particularly as my brain has reprogrammed my driving style to not work to minimize situations where it happens (same thing happened when I got the tune dialed in for rev matching, it takes a while for your brain to realize the car is going to behave predictably and that you don't have to avoid certain scenarios any more. I've also ordered a Gauge.S for CAN/D-bus logging. Thanks toย Bry5onย andย heinzboehmerย I've adapted Bryson's ash tray insert for the Gauge.S to suit an RHD car. I've also ordered the connectors for the Gauge.S board headers, etc. Still to do is to confirm the exact connector used on the steering angle sensor and order a pair to make an extension for the Gauge.S.ย The plan with the Gauge.S is to put everything I can into a couple of custom CAN messages from the DME so that the Gauge.S can log these at high data rate. I've written aย custom program ROMย which allows me to specify the memory addresses of the variables I want to push on the CAN bus in the partial/tune binary. The advantage of this approach is it means that reconfiguring the messages is a simple tune flash rather than a change to the program binary. I can't actually test this until I get the Gauge.S setup, but it's otherwise sitting there good to go. Also while disassembling the CAN functions I uncovered that ARBIDs 0x700 and 0x701 (which are disabled in the 0401 tune)ย can be enabled to send knock manager data. This is going to be super useful for tuning and big thanks to Bryson for confirming the behavior with logging. I've got a bunch of half-finished projects on the go at the moment that I need to finish before I start anything new (which I'm itching to do): ย - Finish the boot/trunk interior work with the RACP brace in place. (I managed to get myself stuck for a while on the best option for the false floor, but think I've got a reasonable option) ย - Finish the SMG expansion reservoir bracket (No blocker here, I just have one that works well enough and need the motivation to sit down and do the final design) ย - Print and install Bryson's Euro M3 bumper to CSL snorkel duct (this one is currently blocked as Dad is having some 3D printer issues with ABS that he is working through) ย - Finish documenting all of the CAN messages on the main CAN bus for the 0401 binary (I mostly have what I need, but want to produce comprehensive documentation on this for the benefit of the community) Think that's all for now... ย Edited July 19 by Karter16 3 Quote Share this post Link to post Share on other sites
Karter16 487 Report post Posted July 26 When deciding on the Gauge.S one of the ancillary decisions I needed to make was how/where to mount it. When he installed his Bryson designed an enclosure to go in the ash tray which is very nice, and I decided I would go with the same approach as it allows for the Gauge.S to be hidden away when not using the screen. It's also an easy swap back to the ash tray at any point. The centre console is specific to LHD/RHD, in that the cigarette lighter is on the driver's side. This meant that the enclosure Bryson designed needed to be mirrored for my RHD to keep the screen centered. Bryson kindly shared the CAD file with me and I was able to quickly make up a mirrored version for RHD. I also removed the features that I don't need (internal mount for the GPS unit and mount/faceplate holes for USB-C charging). The end result looked like this: As you can see it was printed on a textured bed which gives it a lovely effect. Now this all seemed too easy to me, so I decided to make it more difficult by doing a painted finish to more closely match the rest of the centre console components. As always with painting it's all in the preparation: This was then followed by several coats of matte black, before being sanded back to a completely smooth finish and then top coated with several more coats of matte black. I'm super happy with how it's turned out: In person it looks perfect to me, I can't find a single imperfection in the paint that I'd fix if I could. I'll wait for this to properly harden and then do some photos showing it in place. Just got to wait for the rest of the bits to arrive now! 3 Quote Share this post Link to post Share on other sites
Karter16 487 Report post Posted July 27 I got the chance today (making the most of winter before the weather improves and I get started on house projects again) to get started on a project I've been wanting to do for a long time. The goal here is a 1:1 replica of the SMG shifter knob. Why? It occurred to me some time ago that modern manufacturing techniques present an opportunity to create a twist on the stock SMG shifter to make something a little bit unique. The plan is to have the knob 3D printed in titanium and then finish it to a polished surface which will hopefully be a cool twist on the chrome of the original item. The 4 leather pads I'm planning to do as leather-covered TPU with an ABS or similar backing (drawing heavy inspiration here from howย heinzboehmerย recovered the pads on his SMG).ย Why titanium? It is of course a PITA to finish, and it might not end up working out, but I've decided to give it a try for two reasons. Mostly because it's a cool thing to try, secondly - thermal conductivity. One of the nice things about the OE shifter being plastic is that the shifter doesn't feel ridiculously cold to touch on a winter morning. This is because plastic has poor thermal conductivity. Titanium of course has much higher thermal conductivity than plastic, but also it's an awful lot less than stainless steel or aluminium, so will help to reduce this effect. The model above as you see doesn't have the pockets cut for the leather pads, reason being I want to do a test print to make sure that I've got the internal geometries right first in case I need to change anything that affects the pockets for the pads. I'm intending to reuse the OE clear acrylic centre insert which mates the shifter with the shaft, so I need to make sure it's a spot-on fit. Anyway - first draft is being printed and will do some test fitting when I get the parts. In the meantime here are a few screen caps of the two parts: ย 2 Quote Share this post Link to post Share on other sites
Karter16 487 Report post Posted August 1 Well pretty pleased with this for a first prototype. The insert fits perfectly and the two pieces fit together perfectly. I'm stoked that I got the internal geometries right for the insert as they were the hardest bit. I will do some measurements of the prints to make sure they are perfectly dimensionally accurate, and provided they are I need to adjust the seat between the top of the body and the cap by about 0.5mm in diameter and height. The printed cap fits on the OE body, but the OE cap is ever so slightly too large to fit the printed body. I want to make sure I'm as close to the original as possible with this so will make that adjustment. Key thing though is I can now go ahead and design the pockets for the grip pads and include the first iteration of that in the next prototype as well. 1 Quote Share this post Link to post Share on other sites
