77jessejames77 1 Report post Posted March 3, 2017 Hi I'm after some advice. I'm loozing to do a manual conversion on my e28 m535i but trying to find a gearbox has been a real struggle. I'm after a getrag-260 or a 265 I hear the getrag 240 from a m10 would do the job but they seem to be just as rare. I would rather not buy one from overseas if I can avoid it. Does anyone have any recommendations on where I could find one or some other options I could look at? Any info i can get is good info! Cheers guys. Jess 1 Quote Share this post Link to post Share on other sites
HELLBM 1661 Report post Posted March 3, 2017 Can supply the gearbox you need. Regards Ray Quote Share this post Link to post Share on other sites
eliongater 718 Report post Posted March 7, 2017 Don't forget you'll need to weld a mount onto the trans tunnel to support the end of the shift linkage Quote Share this post Link to post Share on other sites
M M 250 Report post Posted March 8, 2017 22 hours ago, eliongater said: Don't forget you'll need to weld a mount onto the trans tunnel to support the end of the shift linkage You can drill a hole and bolt it to the floor like I did, works perfectly fine. Quote Share this post Link to post Share on other sites
eliongater 718 Report post Posted March 8, 2017 (edited) 41 minutes ago, M M said: You can drill a hole and bolt it to the floor like I did, works perfectly fine. Arguably a better solution to use a bolt then. had a thought, why not epoxy? Edited March 8, 2017 by eliongater Quote Share this post Link to post Share on other sites
