mal6 0 Report post Posted March 22, 2017 Friend has offered me 97 a 328 IS coupe manual , lovely condition but it has a stuffed dual mass flywheel & cost of repair almost value of the car . Can it be replaced with a standard flywheel , assuming could find a used 1 .. Quote Share this post Link to post Share on other sites
Olaf 3414 Report post Posted March 23, 2017 I recall reading about new Valeo BMW Flywheel Conversion Kits that convert from dual mass to conventional flywheel with new clutch disk and pressure plate, release bearing, bolts. They're around, see what your local supplier has. HTH Quote Share this post Link to post Share on other sites
KwS 2448 Report post Posted March 23, 2017 You can convert to a single mass M40(?) flywheel and clutch. Had one in my 323i, rattled like crazy at idle, but drove pretty good. Quote Share this post Link to post Share on other sites
mal6 0 Report post Posted March 26, 2017 Seems BMW fitted bothDMW & standard cast FW to E36 s any way of telling externally which it has ? Certainly put me off buying a car with DMF from all the problems ive read about it Ddid they continue it with the E46 ? Quote Share this post Link to post Share on other sites
eliongater 718 Report post Posted March 27, 2017 1 hour ago, mal6 said: Seems BMW fitted bothDMW & standard cast FW to E36 s any way of telling externally which it has ? Certainly put me off buying a car with DMF from all the problems ive read about it Ddid they continue it with the E46 ? IMO they're really not that much of an issue. If it's on it's way out just buy a single mass or stump up the cash for a new DM Quote Share this post Link to post Share on other sites
