pommy 33 Report post Posted April 9, 2017 Hi, I am trying to source a E30 manual conversion & M50b25 engine? Cheers. Quote Share this post Link to post Share on other sites
Mr Vapour 76 Report post Posted April 9, 2017 Any reason why m50 not m52? Quote Share this post Link to post Share on other sites
pommy 33 Report post Posted April 9, 2017 No.... I actually wanted to do m52. But was told the "b25" was quicker due to the inlet manifold & more of a chance to quickly source one? Quote Share this post Link to post Share on other sites
BM WORLD 1295 Report post Posted April 9, 2017 have a nice m52b25 and manual kit from 97 323i coupe if that interests you Quote Share this post Link to post Share on other sites
Mr Vapour 76 Report post Posted April 9, 2017 The m50 is like 60kg heavier and it's.a easy swap to.fit the m50manifold to a m52. Talk to Brent he will sort you out! Quote Share this post Link to post Share on other sites
pommy 33 Report post Posted April 9, 2017 59 minutes ago, 1BMF said: The m50 is like 60kg heavier and it's.a easy swap to.fit the m50manifold to a m52. Talk to Brent he will sort you out! Thanks, I need all the help I can get.... Cheers will talk to Brent. Quote Share this post Link to post Share on other sites
pommy 33 Report post Posted April 9, 2017 1 hour ago, BM WORLD said: have a nice m52b25 and manual kit from 97 323i coupe if that interests you Cheers Brent, I will contact you. Quote Share this post Link to post Share on other sites
HELLBM 1691 Report post Posted April 10, 2017 Re. our discussion. We have M50B25 vanos or non vanos in stock. Also a selection of M52B28`s along with E34 sump kits and E30 manual conversion components. M54B30`s also available. Anything that needs ews delete we can also accommodate. Quote Share this post Link to post Share on other sites
pommy 33 Report post Posted April 11, 2017 Thanks Ray Quote Share this post Link to post Share on other sites
duvey 245 Report post Posted April 11, 2017 (edited) I have a ZF manual 328i e36 driveshaft and a getrag 260 with the corresponding larger output flange if you're interested - should make for a plug and play gearbox & driveshaft combo Edited April 11, 2017 by duvey 1 Quote Share this post Link to post Share on other sites
