dirty36 0 Report post Posted May 20, 2017 So I've stripped the bolt hole that holds the rear strut to the trailing arm pretty badly. The bolt can pretty much be pushed through. What do you reckon is the best way to go about fixing this? Cheers. Quote Share this post Link to post Share on other sites
sweetm3 180 Report post Posted May 20, 2017 ps://www.bimmerforums.com/forum/showthread.php?2299343-DIY-How-to-fix-threaded-rear-shock-aka-how-to-helicoil 1 Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted May 20, 2017 Fit 2nd arm & bolt. I would not use a heli coil for this repair 1 Quote Share this post Link to post Share on other sites
dirty36 0 Report post Posted May 21, 2017 On 5/20/2017 at 3:56 PM, *Glenn* said: Fit 2nd arm & bolt. I would not use a heli coil for this repair Are there any write ups about removing the trailing arm/ handbrake cable? Quote Share this post Link to post Share on other sites
zero 1162 Report post Posted May 21, 2017 1 hour ago, dirty36 said: Are there any write ups about removing the trailing arm/ handbrake cable? There are many on google. Its not overly difficult, and means you get to check the condition of your handbrake shoes etc. Easiest to replace the entire arm and axle from one from a wrecker, otherwise you end up mucking around with bearings. 1 Quote Share this post Link to post Share on other sites
