Michael. 2313 Report post Posted August 9, 2017 Hey lads, I require some tig welding in Auckland Stainless fitting 28mm diameter welded onto this MS cylinder as shown. It has a piston inside which is at the opposite end of the welding, so I'd need to supervise and hold some wet rags on that end to keep the temperature down. Weld is shown here with the arrow. Let me know if you can help! Top cash paid! Quote Share this post Link to post Share on other sites
BM WORLD 1295 Report post Posted August 9, 2017 macweld in drury Quote Share this post Link to post Share on other sites
aja540i 1925 Report post Posted August 9, 2017 I can help. What thickness is the ms part? Quote Share this post Link to post Share on other sites
Michael. 2313 Report post Posted August 9, 2017 2 hours ago, aja540i said: I can help. What thickness is the ms part? approx 10mm Stainless part is a decent thickness as well be approx 5mm wall thickness. Could also mig weld it? Quote Share this post Link to post Share on other sites
aja540i 1925 Report post Posted August 9, 2017 Doesnt worry me, can do either. A bit easier to keep the heat input low with the tig though. When do you need it done? 1 Quote Share this post Link to post Share on other sites
Michael. 2313 Report post Posted August 9, 2017 10 minutes ago, aja540i said: Doesnt worry me, can do either. A bit easier to keep the heat input low with the tig though. When do you need it done? Still waiting on the elbow piece, so after that, not urgent. Looks like its due early next week. Yeah heat is the main thing to keep down hence thinking tig. What sort of scheduling suits you Andrew? I'm totally flexible so whatever suits you best. Quote Share this post Link to post Share on other sites
aja540i 1925 Report post Posted August 9, 2017 Im around most evenings and weekends, just pm me when the part arrives and we can sort something. 1 Quote Share this post Link to post Share on other sites
