Michael.
Who can Tig weld for me?
Hey lads, I require some tig welding in Auckland
Stainless fitting 28mm diameter welded onto this MS cylinder as shown.
It has a piston inside which is at the opposite end of the welding, so I'd need to supervise and hold some wet rags on that end to keep the temperature down.
Weld is shown here with the arrow.
Let me know if you can help! Top cash paid!
I can help. What thickness is the ms part?
approx 10mm
Stainless part is a decent thickness as well be approx 5mm wall thickness.
Could also mig weld it?
Doesnt worry me, can do either. A bit easier to keep the heat input low with the tig though. When do you need it done?
Still waiting on the elbow piece, so after that, not urgent. Looks like its due early next week.
Yeah heat is the main thing to keep down hence thinking tig.
What sort  of scheduling suits you Andrew? I'm totally flexible so whatever suits you best.
Im around most evenings and weekends, just pm me when the part arrives and we can sort something.
